#26 | |
Still Learning
Re: Bumper bracket mounting questions
The aftermarket bumpers are thinner and the steel is very soft too, so you want to use Loctite and be careful tightening your bolts. |
#27 | |
![]() Join Date: Feb 2009
There's something to be said for keeping the step bumper. Mine included a receiver hitch as well. The hitch may have been a dealer option.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#28 | |
#29 | |
#30 |
What's the policy on giving stuff away? I don't do CL, but have given a lot of stuff I no longer need to other board members. Biggest thing was a longhorn camper, but lots of small stuff too. Don't want to pay for the privilege.
#31 |
Well it took like 4 hours but I finally got the old bumper off yesterday. I found the air powered cut off tool to be pretty worthless. I have the best compressor you can have on 110V: Husky 30 Gal and it would go for 2-3 minutes before the compressor kicked on and the oil lubricated cast iron pump seemed to keep up just fine (though I did not push it too hard). The issue was at 100psi it just didn't have the power to go through the welds. It cut through thick pieces of mild steel quickly but I guess the welds are of a harder steel. I ended up using my angle grinder not with a cut off wheel but the thicker metal grinding wheel. This combo was easy to work with and I was able to remove all of the welds with just two wheels. It took about 4 hours to get through all of the welds and remove the bumper with the huge elaborate bracket system. I then got lucky and the new bumper with brackets went together easily. The only issue I had was the holes for the gravel shields did not line up with the brackets so I left them off figuring I would measure and drill new ones when I had more energy (I was pretty tired by then).
In all the truck looks great and the license plate is now visible so I am no longer worried of being pulled over for that. I have no real plans of towing with this truck but if I do I think there are frame mounted receiver hitches that I can mount.
1971 Cheyenne Big Block Longhorn Last edited by Jonlopes; 05-18-2015 at 03:13 PM. |
#32 |
Glad you got it off. Light pressure is the key to the cut-off wheels...let the machine do the work. Also, you want to keep the speed up on the wheel for best results. It is that lack of torque that keeps you out of trouble. Bottom line is you got it off and no injuries to talk about.
