#26 |
Post Whore
![]() ![]() Join Date: May 2015
Re: C30 GMC Dually
JD i am unaware and may be wrong of a wheel base change from 1980 to 1981. They did change between 72 and 73 though..67-72 swb is 115" lwb is 127" then from 73-87 swb was 117.5" and lwb was 131.5". so I would think any lwb bed would fit...1 ton may be different wheel base.. only change I know of in 81 was the new sloped hood design.
#27 | |
Posted via Mobile Device |
#28 |
Post Whore
Re: C30 GMC Dually
I wouldnt know about that. May be a difference between 1 ton and pickup wheelbase, but thats the short and long wheelbases for pickups from 73-87. 117.5 and 131.5....cut and weld..make it fit..thats what i did to mine.
#29 |
Re: C30 GMC Dually
Nice truck to start with. Short cab & chassis trucks take a bed with 60" cab - axle measurement and longbed pickups take 56". No change in length 73-up. In fact, cab & chassis prior to '73 take 60", too. If that's a GMC then it's a C35. People call all dual rear 1 tons duallys, even other brands. GM coined the term for their new pickups but it wasn't dually, it was "Big Dooley"
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 05-13-2015 at 09:38 PM. |
#30 |
Kansass Fire Starter!
Re: C30 GMC Dually
Mine is a GMC
#31 | |
#32 |
Re: C30 GMC Dually
So can someone tell me the measurement for a short bed compared to the long bed so I can make sure exactly what I have.
#33 |
Post Whore
Re: C30 GMC Dually
Wheelbase for short bed is 117.5 in ,,, long bed is 135.5. But this would also depend on if someone has shortened or lengthend the frame "to fit" a certain bed..I looked at a couple before I bought mine and they had all been cut, mine came with the 164.5 wb which is why I had to cut out so much to make it a short wheelbase..mine was a regular cab on a crew cab chassis..just looking at your pics I think yours is short.
#34 | |
#35 |
Re: C30 GMC Dually
Mine is 135.5
#36 |
Post Whore
Re: C30 GMC Dually
Godfather.. mine is 135.5 now , its what I ended up with after I cut my frame .. I made my bed 8 ft long but it would have looked better if it was 8 ft 6 in.. it kind of looks bobbed off.
#37 |
Re: C30 GMC Dually
So you think mine has been altered?
#38 |
Re: C30 GMC Dually
No. Cab is the same. The frame is 4" longer than a pick up frame. length was added between cab and axle for a longer wheelbase.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
#39 |
#40 |
Post Whore
Re: C30 GMC Dually
Godfather I found this pic while searching for dustless paint removal..this might give you some ideas..just a different way to go about it since yours is already lowered.
#41 |
Post Whore
Re: C30 GMC Dually
Couple more pics
#42 |
Re: C30 GMC Dually
Yeah I like that!
#43 |
Re: C30 GMC Dually
Check this bad boy out. Fully bagged which is also in the plans.
#44 |
Post Whore
Re: C30 GMC Dually
Yeah GF..a guy I work with showed me that one last night...he had a bunch more different pics of it to
#45 |
Re: C30 GMC Dually
Damn!
#46 |
Re: C30 GMC Dually
I plan on 5" the other way.
#47 |
Re: C30 GMC Dually
Nothing wrong with that as long as it's not stock lol!
#48 |
Squarebody guy
Re: C30 GMC Dually
That bagged flat/service bed truck is very nice!
Only other truck I've seen like that is this one on duallyscene ![]()
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress |
#49 |
Post Whore
Re: C30 GMC Dually
Looks good ghost..I had seen pics of that one before and if I had gotten a dually truck instead of a 1 ton I was gonna style my bed sides similar to that.. but not dragging the ground...I use my to pull heavy trailers to much..but it looks good.
#50 |
Re: C30 GMC Dually
If ya build it right it can still pull just as much.
