Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: 50 3100 5 window with Vette suspension
So can the lower section of the c4 cradle where it bolted to the donor car be cut off to clean up the install? And still using the C4 transverse leaf spring?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
![]() Join Date: May 2012
awesome build.. hope to see more as i plan the same thing, just picked up c4 front and rear and don't want to have to buy a 800 dollar crossmember if i don't need to.
Garage Built |
![]() Join Date: Apr 2010
Yup, Ernie is really happy with it. I did that one. It was a lot of fun, and a real learning experience.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
I bet it handles amazing!
You don't happen to have any of the measurements do you? I was just hoping to save a few hours if you did! I always double check measurements anyways but anyone with experience doing it or someone who has experience with it would be a great help to me doing mine maybe save some heart ache.
Garage Built |
Hope I'm not bugging you too much but wondered if you had any front sheet metal alignment issues with the slight widening of the frame to accommodate the stock vette k member. By my quick measurements it only needs to widen aprox 1/4 each side or there about where itll mount..
Garage Built |
