Old 05-22-2015, 03:00 PM   #26
Liltroy
Liltroy's Avatar
Re: driveshaft options
Originally Posted by mattcrp1 View Post
I had to do a drive shaft for my 76 4.8l 4l60e, I bought a used 2002 1500 aluminum shaft out of a standard cab short bed (that what LKQ told me). I took my measurements and went to a drive line shop.
The part that took the most calculation was figuring out the correct conversion joint to mate the new drive line to the old differential pinion flange. I figured I saved about $100.
this is what I plan to do as well
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
Old 05-24-2015, 12:15 AM   #27
mattcrp1
mattcrp1's Avatar
If you already have a drive shaft to start with it will be alot less money. The shop i used charged $130 to shorten the shaft. This is the second drive shaft I have had done. It does not appear to be an exact science, but close.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
