#26 |
Re: Big Parts,4x4 stuff, Possible delivery MN, IA, NE, KS, OK, NM, CO, NW TX
Jud, 125 works for the trans. I would prefer the cleanest of either a two or three core radiator. Pics would be nice. Thanks
#27 |
![]() Join Date: Feb 2014
Jud, I am interested in the T-case and the paint rim divider. Are you going near Mulvane, KS? I am in negotiations to buy a couples of pieces, but shipping is going to kill the deal. A GMC rad support and a heavy rear bumper. Would you be willing to pick up and bring back or is it too far out of the way? Bruce
#28 |
I would be interested in a eaton rear axle as well damaged brakes is fine, also I saw in one of the pictures a set of 3/4 ton spicer hubs do you still have those? This would be delivery to Colorado spring. thanks Jeremy
#29 | ||
Vintage 4x4s
Jeremy, Spicer hubs not available at this time, going to keep with axle for now. I will be coming back through colorado springs and could drop off that Eaton with the damaged brakes for $200 total.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#30 |
Jud, when do I have to let you know? What I mean is when are you coming through and coming back, roughly. There is a John Deere dealer (Horizon Equipment) just east of I-29 at exit 75 (less than 1/2 mile off the Interstate). I do a lot of business with them and know the guys there. I would just have you drop the stuff do and back there. If that you be okay with you. Bruce
#31 |
Vintage 4x4s
Derrick, Pics of 2 core radiator, its nice but I haven't pressure tested it (not set up to) but needs the overflow fitting soldered or pressed in. This is the best 2 or 3 core I have, and best I've seen for an original Harrison 2 or 3 core and I have 6 here. Fins are straight and corrosion is superficial/staining. It looks bad on the bottom but that bottom row is solid. I would say the odds are pretty high it won't need anything more than a cleaning and painting. There is some scale inside that you may want to hot tank clean, but the passages are open. Since you're taking the trans, I'd do this for another $75, so $200 total.
#32 |
Jud the radiator looks nice. Please bring it down. How much more for the 3OT linkage and hardware w/bushings on the column? Also I noticed the lower black trim on the blue truck and others. If you don't plan on using for other projects would you sell a nice set for doors and fenders only? Thanks
#33 |
I will take the eaton with damaged brakes, also do you have a complete front dana 60 by any chance you would sell. Thanks Jeremy
#34 | |
Vintage 4x4s
Sounds good Jeremy, I have a nice dana 60 from a dodge actually but its spoken for. I will see if he for sure is going to take it.
#35 |
Vintage 4x4s
Pics of good 4 core for tyler.
The description I gave above also applies to this one for condition except there are a couple areas of fin damage (but no leaks) and the overflow fitting is present on this one. ![]() ![]() ![]() ![]() ![]() ![]()
#36 |
All about them K’s
![]() Join Date: Jun 2014
Thanks Jud, what do you want for it? If I can figure a way to get it here I'm very interested.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#37 |
![]() Join Date: Mar 2014
talked to my painter, Jud. He says we can drop the frame off at his shop, and he'll be there to help unload it.
#38 | |
Vintage 4x4s
Jud
#39 |
I can hold parts for you here Tyler no problem.
#40 |
Jud
Do you have a good 67-68 hood? If so how much? I could possibly pick up in Amarillo depending on the date and time. |
#41 |
USPS MO sent Priority from western Iowa on Sat. Payment for T-221 T-case and divider trim. Some extra $ for transport/back haul parts from KS. Thank you, Bruce
Posted via Mobile Device |
#42 |
Vintage 4x4s
Thanks Bruce, I will let you know if it doesn't show up.
Got the house/guard dog sitter all lined up, YE9longhorn30 and I are planning to leave Friday am. We're shooting to be in ABQ Sat afternoon/eve or so, and colorado monday-ish. ![]() Jud
#43 |
All about them K’s
Thankyou, it will probably be about 3 weeks to a month before I'll be back down there. If that is ok with you, then I will take it Jud.
#44 |
#45 |
Vintage 4x4s
Cool, thanks Derrick. Sounds like I'm also bringing a bumper for Pete.
Tyler, got your down payment on the 4 core. Thanks, Jud
#46 |
Jud-
I didn't see it listed, but would you have a super straight rust free long bed, (metal floor)? Also any 72 only real clean below eye line mirrors? Thanks, Bill |
#47 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Jud thanks and LMK how I can square-up. Thanks Derrick.
Drive safe Jud.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#48 | |
Vintage 4x4s
Pete, no problem I think we're square, for that item in ABQ you helped me with ![]()
#49 |
![]() Join Date: Mar 2012
do you have a nice set of these hubs for dana 44
#50 |
![]() Join Date: Nov 2014
I'll take a 4x4 frame to texas, just realized this post was older. If you have anything let me know
