Old 09-03-2003, 01:22 PM   #26
Southpa
Southpa's Avatar
Even so, 30K miles on a farm are hard miles. Hows it look underneath? All the cab supports, mounts etc. in good shape? Also, check the bolt channels inside the rear wheel well tubs. A truck doesn't necessarily have to be moving all its life to rust out.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 09-03-2003, 05:44 PM   #27
bpmcgee
bpmcgee's Avatar
Wow, cool! I didn't know there were any V6's offered. I thought there were only inline 6's and V8s!
What a fupid stuck eh?
Brian
bpmcgee is offline   Reply With Quote
Old 09-03-2003, 05:48 PM   #28
1969 GMC
1969 GMC's Avatar
There shouldn't a M or D in the VIN?...
I ran into this problem myself, well not the M part. M does stand for V6 gasoline, and the OD stands for wide side pickup bed (fleetside), which seems to be a GMC only code.
30k miles in 35 years and needed to be repainted?? Come on.
Ever heard of the sun? I will add on to the list of ppl who have bought their GMC 3/4 ton 4x4 from a farm, only mine was in Minnesota. it had about 82k, was used to pull a trailer with tractors on it, which explains the pintle hitch. the sun took a beating on the paint, somewhere along the line they did a farmhand repaint on it, and they actually made it look worse than it was before. they also went a little nuts with bondo in the little dings on the bedsides. funny thing is, my dashpad is in mint shape. hmm.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-03-2003, 11:44 PM   #29
casey
casey's Avatar
My 71 4x4 has 60,000 miles, and it isn't a farm truck, the motor has never been apart, I found a good way to tell if your truck has more miles than it might say, I took my truck in to get one back spring rearched, and the spring man took the leaf apart, and said to me this must be a low mileage truck, I said why do you ask, he said you see where theses leafs over lap each other, on a higher mileage truck the end of the leaf wears a good size groove in the leaf above it, theses are like new, and they have never been out
casey is offline   Reply With Quote
Old 09-04-2003, 12:04 AM   #30
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Good tip casey
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 09-04-2003, 07:34 AM   #31
ryker77
Good tip thanks
ryker77 is offline   Reply With Quote
Old 09-04-2003, 08:44 AM   #32
griesel72
griesel72's Avatar
Thanks for the tip, casey,
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 09-04-2003, 09:18 AM   #33
Randy70C-10
Randy70C-10's Avatar
Damn, I would have never thought of that. I'm going to check mine.
Randy70C-10 is offline   Reply With Quote
Old 09-04-2003, 09:46 AM   #34
truckster
truckster's Avatar
That V6 will run forever. You really can't break them. They're modified from a diesel design and everything in them is super heavy-duty. I had one in a 66 GMC and it got 14 mpg uphill or downhill, load or no load.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-04-2003, 12:41 PM   #35
ryker77
Everything sounds good
Old 09-04-2003, 04:05 PM   #36
oldsub86
I don't know exactly how many miles my truck has on it but I do know that I have only put about 13-14K miles on it in the approximately 18 years that I have had it. It was an old truck when I got it and I bought it just to be a 3rd vehicle - sort of a backup and junk hauler locally. I have had it as far as 200 miles from home but only twice in that 18 years. Mostly it sits - outside- and the paint has about had it just from age. Low low miles is not impossible but one should look real real close for signs to justify the claim.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
