#26 |
Re: 1973 Regular Cab Dually
thats some sweet literature im jealous!
i also just got some Squarebody Syndicate merch. the 3 pack of stickers. VERY high quality stickers! |
#27 |
Looks like a aftermarket secondary fuel tank. Probably has a butterfly lever or knob somewhere on the floor (next to hump or just under the front of the seat) to manually shift from the factory tank to the aftermarket tank.
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
#28 |
Always a work in progress
Awesome looking truck!! I would love to have one of these as a towing vehicle.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
#29 |
Gregs71 you are correct. There are two switches, one on the dashboard (aftermarket) next to the brake controller and another on the floor right beside the drivers seat. Both work but they both have to be switched to the same tank at the same time to work.
#30 |
This truck is like the gift that keeps on giving. When I bought the truck I noticed there were some tools wrapped up in rags behind the seat (or so I thought). Today my curiousity got the best of me so I opened them up to see what was inside. Turns out its the anchors for the overhead camper if you had one. I may be wrong but thats' what I think they are.
#31 |
So for the last couple of days I have been doing the brakes on my truck. The fronts just needed pads and a good cleaning while the rears need everything. Brake shoes, hardware, wheel cylinders, axle seals etc etc. In my attempt to swap out wheel cylinders the new ones are 1/4 wider preventing them from seating correctly and not fitting between the bracket on the backing plate. So I break down the old and the new cylinders to see if the piston sizes are the same so I can rebuild the old cylinders. Well after a good degreasing I realize these may be the original wheel cylinders that came with the truck when new. Talk about character. I just think today's parts are made to be disposed of while the old parts where built to be rebuilt and reused. I hope they don't leak once rebuilt. I look at the casting and think if they could talk what kind of stories would come from the miles these have seen.
#32 |
Its not letting me upload my pictures. Telling me a security token is missing.
#33 |
Wow, that's a very nice truck. Mine also seems to have been a CA truck it's whole life, but has some floorboard rust issues... I hope yours doesn't, I didn't even think to look there with no holes elsewhere.
For pictures, I'd suggest uploading them to www.imgur.com and then img tagging them here. A feature of imgur that most sites don't have is that you can put various letters immediately before the .jpg to resize them, so they aren't huge. h (for "huge") is the size I typically use, I think it's 1024x768, which is a reasonable size for forums. l (for "large) is 800x600, a little small for today's monitors. http://imgur.com/yWP94kU is a picture of my truck that I uploaded. To the right of the image, you'll see a Share This Image section. You'd need the BBCode option, which is: [i mg]http://i.imgur.com/yWP94kU.jpg[/img] or, the smaller "h" version [i mg]http://i.imgur.com/yWP94kUh.jpg[/img] For both of those I put a space in the middle of img, to not clutter up your thread with pictures of my truck, and let you see what's written. Without the space (as they appear after uploading), they'd appear as images.
1973 C20, 350/350 |
#34 |
I love that truck!
I just bought a 73 flat bed dually last week. Have you had any luck with those front rotors though? Nothing but dead ends for me so far. |
#35 |
![]() Join Date: Feb 2011
Super Nice score of a truck and all the documentation as well; So nice!
MusicMan70 1961 GMC Suburban |
#36 |
HillbillyJr
If I recall the front rotors were available. The back however is a different story. Still haven't been able to find a set of drums but the truck has been on the back burner for now while I work on another project. Thank you MusicMan70. |
#37 |
Well that's uplifting to hear. I would greatly appreciate a part number and/or location where you bought them, as I have exhausted every effort in my search for new or used front rotors for this truck.
#38 |
Any updates or progress on this awesome find? .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
#39 |
Not much lately. Swapped out the points distributor for an HEI and tuned up the truck. I need to replace the fuel lines (dried rubber lines) on the tank and get the timing set better.
#40 |
Maybe.
84 step side 87 swb |
