Old 05-30-2015, 08:02 PM   #26
71swb4x4
71swb4x4's Avatar
Re: Need help?!?
That picture makes it look pretty straight. Just a dent in that top rail, but that shouldn't affect much.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-30-2015, 08:04 PM   #27
FirstRide
Re: Need help?!?
Any idea from what could cause the difference in measurement then if the support is straight?
FirstRide is offline   Reply With Quote
Old 05-30-2015, 08:19 PM   #28
leftybass209
leftybass209's Avatar
Re: Need help?!?
45+ years of living life as a truck can be hard on a truck. There's no way of knowing what is wrong with your truck without an extensive history on it.
leftybass209 is offline   Reply With Quote
Old 05-30-2015, 09:20 PM   #29
kwmech
Re: Need help?!?
look up from the bottom and see if the x-member is straight across or pulled forward. At the tip of the frame rail where the bumper mounts how far across are the rails. Should be really close to 28 1/4''
Old 05-30-2015, 09:30 PM   #30
57taskforce
All about them K’s
57taskforce's Avatar
Re: Need help?!?
You could take it to a body shop and have them measure the frame for square. That will tell you a bunch(or if your good with a tape you could do it your self).. From there you can move the cab/ front sheet metal if the frame is square
Tyler
57taskforce is offline   Reply With Quote
