Old 06-10-2015, 06:54 PM   #26
Chevy Fleetside
Chevy Fleetside's Avatar
Re: I should have listened to you guys...6 lug to 5 lug conversion
On the 2" brakes the backing plate will be shallow. The 2 1/2 brakes will be deeper. If that makes any sense. I am sure there are late model 2" brake drums. Check out Rockauto.com .
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-11-2015, 12:48 AM   #27
Captainfab
60-66 Nut
Just to clarify. You can not use the '71-'87 5 lug axles in a '63-'70 12 bolt housing. They are 3/4" too long.
If you want to upgrade to the 2-1/2" wide rear brakes, you must change the backing plates also. That is where the extra 1/2" is.
Old 06-12-2015, 11:44 AM   #28
donthekawguy
donthekawguy's Avatar
I just swapped my axles about a month ago. I used the Speedway kit that I got from a guy on CL who got the wrong kit for his 71. Saved me about $100! I also put new bearings and seals in while I had it apart. The kit is nice and the axles are thicker than the stock ones. The drums have cooling fins and the lugs are bigger than stock. All that added up makes it a stronger set up for sure. I have 15x10 rally wheels on the back with 4.5 inch backspace. 295/50/15 tires but you will have to roll the lip or do like the PO of my truck did and cut it out.
66 shorty
donthekawguy is offline   Reply With Quote
Old 06-12-2015, 12:34 PM   #29
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by donthekawguy View Post
I just swapped my axles about a month ago. I used the Speedway kit that I got from a guy on CL who got the wrong kit for his 71. Saved me about $100! ...
So you bought those huh.
Old 06-12-2015, 01:01 PM   #30
par4tom
Hey there,
No reservations about the Speedway kit then? I saw those but hesitated due to the fact that the kit was so cheap, not to mention the "China thing" which today is really not that big of an issue.
I am going to put mine on stands tomorrow and get started with this transformation...
Drove it to work today for the first time and it's a hoot to drive...
I just measured from the inner fender lip to the inside of the tub/bed and there is 13" of space in there...probably about 12" that is usable. Looking at an 18x11 wheel at this point.
T
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
