Old 12-04-2015, 03:17 AM   #26
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Project Roxy
Any updates?
Rich
1972 K5 Blazer CST Click HERE
Old 12-10-2015, 03:08 PM   #27
Domer
Domer's Avatar
Re: Project Roxy
Ya, i have a few, been out to sea a lot. I'll try and get some pictures uploaded soon.
Project Roxy...
Shes Bad, Low, and Blown...
http://67-72chevytrucks.com/vboard/s...d.php?t=673333
Domer is offline   Reply With Quote
Old 12-22-2015, 09:49 PM   #28
Domer
Domer's Avatar
Re: Project Roxy
Here are some updates. I have been out to sea alot lately, and have a pregnant wife right now. Our first little girl. so i work on it when i can. I kind of put it together and rolled it outside to work on my buddies c10. My buddy got me some time on a frame table, so i had my frame straightened out. It was dog tracking abit. so 9 hours on the table, its straight as an arrow now. Here are what i have for pictures and updates right now. Its just a frame at the moment.
Project Roxy...
Old 12-22-2015, 10:00 PM   #29
Domer
Domer's Avatar
Re: Project Roxy
SO my final geometry came out to 8* caster, -1* camber, wheels centered in wheel wells, and 11" drop in the front, 7" in the rear(for now). I/C and Roll Center came out pretty close. Still think i am gonna add a +.5" upper balljoint to improve R/C a little bit.
Project Roxy...
Old 12-23-2015, 02:24 AM   #30
Matt Man
Matt Man's Avatar
Re: Project Roxy
Great looking truck, nice to see someone put a supercharged engine in their c10 instead of a ls motor.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 12-23-2015, 01:32 PM   #31
tinydb84
tinydb84's Avatar
Re: Project Roxy
Looks great man. Is that tube on the outside of the frame an outrigger for the cage or something?
How far off the ground is your lowest part? (I am wondering how low I want to set my ride height right now)
David
Instagram: myfabguy
Old 12-23-2015, 02:39 PM   #32
Domer
Domer's Avatar
Re: Project Roxy
The tube out rigger will eventually be where my cages attaches. It has alot more reinforcement to do first. My frame and control arm shafts are about 3" from the ground, and the coil buckets are about 1 1/2".
Project Roxy...
Old 01-09-2016, 11:56 PM   #33
Domer
Domer's Avatar
Re: Project Roxy
Built the base layout for my center support section. Still need to connect them and add a driveshaft hoop. It's all built from 3/16 steel. Still have to the back half. But making progress.
Project Roxy...
Old 01-09-2016, 11:59 PM   #34
Domer
Domer's Avatar
Re: Project Roxy
Project Roxy...
Old 01-24-2016, 06:36 PM   #35
Domer
Domer's Avatar
Re: Project Roxy
Got the body fitted today. Last updates as I will be deploying.
Project Roxy...
Old 01-25-2016, 03:27 PM   #36
mattcrp1
mattcrp1's Avatar
Re: Project Roxy
Looks good.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 01-25-2016, 04:05 PM   #37
Domer
Domer's Avatar
Re: Project Roxy
Thanks man.
Also, for ride height, I have 3" under frame, 4" under control arm shafts, and 2" under control arm pockets. Now I need to notch the front frame rails to raise my Sway bar up higher.
Project Roxy...
Old 09-13-2017, 03:27 PM   #38
Ben_Yeaton
Re: Project Roxy
Any updates on this? Badass build man, just ran across it searching for caster mod info. Hope all is well!
Ben_Yeaton is offline   Reply With Quote
Old 09-14-2017, 12:08 AM   #39
Domer
Domer's Avatar
Re: Project Roxy
I've made some progress.. dont have any pictures uploaded. I put a 9" in it with 4:10 gears and Detroit Locker. 3 linked the rear and put it on coils with adjusters. Right now I'm stalled, as I was changing some things on my engine and found metal in the oil pan. Further inspection showed I wiped out cam bearings.. so rebuild here we come..
Project Roxy...
Old 09-14-2017, 12:41 PM   #40
daddyjeep
daddyjeep's Avatar
Re: Project Roxy
Roxy is a beast. I love that you are building the chassis to be so rigid. She should handle good.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 09-14-2017, 04:02 PM   #41
Domer
Domer's Avatar
Re: Project Roxy
Thanks. I'm hoping she handles as good as i think it will.. weight is still an issue so we will see after this. Just need to finish up the other projects in my driveway and garage so i can get back to work on her.
Project Roxy...
Old 09-15-2017, 01:56 AM   #42
LT7A
Re: Project Roxy
Glad this thing is still happening. Those 305s (tires) look really cool.
Old 01-22-2018, 11:40 AM   #43
808_67C10
808_67C10's Avatar
Re: Project Roxy
Dayummm... I am stoked to find this thread. Love where you are going with it. I just picked up a 85 in Cali and its on the way here. I ran 20x10s all the way around on my 67 and it took some figuring out. I love the idea of the Jeep SRT8 wheels. Been looking for something different and these never crossed my mind. Hella killer fab work too, very impressive thought process going into making everything work. I am in for the long haul. Retired Navy myself - I built my 67 over 2 sea tours. Its tough but, you are crushing it!!! Cant wait for more updates.
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
