Old 06-12-2015, 01:41 PM   #26
davepl
davepl's Avatar
Re: drove 20 miles to work now won't turn over
Originally Posted by MARKDTN View Post
Same ones fit either SB or BB.
Fit, yes. Same, no. Don't put a small block starter on a big block (or at least not one with any compression or timing) as they're weaker.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-12-2015, 10:09 PM   #27
hdff
hdff's Avatar
Had an opportunity to drop the starter today, I think I might have found part of my problem. Pic is in reply #28 below
What is the wire harness that goes from the firewall block to the starter called if I wanted to replace it. ThE purple wire is the only one that is not cut but it is nicked near the connection at the firewall, the other 3 wires are just cut and laying in a wire loom, I have no idea where they are suppose to go, there is a pink a green and a tan.
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 06-12-2015, 10:11 PM   #28
hdff
hdff's Avatar
Ok here is the battery to starter wire, the one above is the one I couldn't get to dload in the previous post.
"Wanda"
Old 06-12-2015, 11:37 PM   #29
Sklptrljay
Sklptrljay's Avatar
Yup......that will do it.
Plastic insulation vs white hot headers.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 06-13-2015, 01:34 PM   #30
davepl
davepl's Avatar
I do hope all the dissenters and OP send me flowers.
I wouldn't describe that one as the battery to starter, I'd call it ignition to solenoid.
Old 06-13-2015, 02:38 PM   #31
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The harness that comes of the firewall and has all the wires for the ignition and starter is called the "engine wire harness".
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-13-2015, 03:37 PM   #32
davepl
davepl's Avatar
"Engine & Starter Wiring Harness" depending on who you ask, but it's a minor point.
Varies by engine and transmission, but M&H is my preferred manufacturer. Check board vendors first, they're here for a reason and are often cheaper. Here's an example, though this is manual trans:
http://www.ecklerstrucks.com/chevy-t...1958-1959.html
