#26 |
Re: new here! needs brake shoes...
#27 |
#28 |
#29 |
#30 |
#31 |
#32 |
#33 |
41/11=3.72 gear
july 1979 year... Am i right or wrong? If im right ,where do i find parts... Where do you buy parts for your truck? Need parts for the 66,and for my 69 chevy... ![]() |
#34 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yes you are correct. You have a 1979 10.5" full floating 14 bolt with 3.73 gears.
I buy my brake parts locally, so I'm not sure what online supplier will ship to Sweden. Maybe Summit Racing or Rockauto? Do you need parts other than brake parts?
#35 |
He NEEDS a U-bolt saddle (see post#30)
#36 |
60-66 Nut
Aaahhh I missed that.......yes he does. I'll have to look and see if I might have one or two.
#37 |
Thought you might have
#38 |
#39 |
![]() ![]() Join Date: Jul 2002
Your wife's truck is really neat looking. I like how the panel pieces came together for the cab.
#40 |
Hard to really see with a rule BUT it looks like you NEED drums ....... yours LOOK to be way over the MAX ID. LOOKS to be about 13.125
#41 |
#42 |
60-66 Nut
Sorry but I've been extremely busy and have not remembered to look. I will make a note to remind myself.
#43 |
60-66 Nut
Sorry but I do not have any of that style saddles. GM started using that style around the late 80's up into the 2000's.
#44 |
Thanks for the help guys...
Found the saddles on ebay... And the brakeparts etc at the local autoshop.... now i just have to wait.... Its allot easyer to find the right parts when you know what to look for, the right year and so on.... The wife says hi and thanks..... ![]() |
#45 |
60-66 Nut
Glad to hear that you found the parts you need.
Hello wife ![]()
#46 |
so finally new brakes and then some
Just wondering how the wheelbearing gets lubrication! Maybe a stupid Question,but i wonder because i havent taken the rear brakes apart until now... Is it from the oil in the diff than runs down the tube? must be ...or..... On our other cars there is grease but on this one there where grease and oil mix together.. .And that cant be right! |
#47 |
Yes it gets lube from the DIFF. BUT you need the pack some wheel bearing grease on/in the cones when you install them or you CAN/WILL wipe out the bearings as there will be NO oil from the DIFF. for awhile .... I have seen it happen.... Also make sure there is some preload on the bearings when done (NOT LOOSE) there should be NO end play in the hub when done
#48 |
ok thanks.....
