#26 |
Re: Unfortunate News
I'll have to take it out again tonight and take a really keen listen to my shifting and see what happens...
1981 ![]() |
#27 |
Where the shifter sits, what it's pointing to, and what gear is actually selected aren't necessarily the all same thing.
Ron Sessions' book "Turbo-Hydramatic 350 Handbook" says no 2-3 shift could be a valve-body malfunction, a front-pump malfunction, or a direct-clutch-circuit break. If you are not actually shifting into 3rd, you should probably take the transmission back to whomever built it.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#28 | |
1981 ![]() |
#29 |
Pull it down in 1st manually shift 2nd then 3rd or Drive id say your not getting out 2nd
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
#30 |
If I have the chance to take it out tonight and drive it, I will do the manual shift test, to see what happens
1981 ![]() |
#31 |
![]() Join Date: May 2001
With a 350 turbo and 3:08 gears you should be able to cruise on the highway no problem. Like the others have said, something's not right. Either your in 2nd, or you don't have a 3:08 rear end.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
#32 |
10-4. I'll get an update posted here. I've had some troubles with the vacuum line in the past. I had an episode where it would barely shift from first to second, and bang into 3rd, all because of a leaky rubber mount on the main vacuum line. I'll give it a check and see what it looks like. I'll update as soon as any news is discovered.
1981 ![]() |
#33 |
This just in! Good news. After much sitting in the dead quiet and eliminating possibilities, I decided to check the main vacuum line. The line to the modulator had partially slipped loose on both ends, and was leaking air out of both ends... A little gentle bending and fiddling, and she's tight as a drum. Went for a good 20km test drive, and the RPM's are at least 1000 lower at cruising around 100km/h. Very good news... Seems much more reasonable as a transition from 2.73ish to 3.08. Thank you all for the help, I find this forum to be an invaluable tool for looking into problems, without the "doctor" having to charge $100 just to look at it... Thanks guys!
1981 ![]() |
#34 |
Thumbs up
#35 |
And there was much rejoicing.
#36 |
I like stories with happy endings.
#37 |
![]() Join Date: Jul 2014
I had a similar problem on my '74's 350TH. It would seem to shift through all three gears but is was actually skipping a gear. I could manually shift it through all three gears but when in drive it just wouldn't do it. What I ended up with was the throttle linkage snap ring was not seated fully in the throttle cable bracket after doing my engine swap. Once we got that settled out, (a simple 1 minute fix) it has shifted great ever since. Not sure if yours has the same setup, but you are sure describing what I experienced.
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
#38 |
Glad to hear it was something simple.
