Post Whore
![]() ![]() Join Date: May 2015
Re: Can my truck pull this?
That stock 5.3 swap will add about 100 hp over what your stock 5.7 has,,, and you will love the extra mpg....
Yeah I've decided I'm going to do it one of these days.
Also, 2 more questions. 1. You can see in the first pic that the trailer tongue is slightly tilting down some. All I could find at walmart was a 2" drop hitch. Couldn't find any that were just flat, or were only 1" drop. Does it look to you guys like that's too low? 2. Also in the first pic, you can see the wire loom for the trailer lights hanging down. That seems kind of like a bad idea to me. Its hanging kind of low, and something might come along and get caught up in there. Should I try to affix it to the top of the tongue? Or does it have to have some room for when you turn? |
Those were my first thoughts when I saw the pictures, I would change the drop on the hitch, and an actual auto parts store (Napa, O'Reilly, Autozone) would probably have a much better selection of hitches and drops than your local Wal-Mart.
Just keep in mind that with any trailer, higher on the front hitch equals lower on the tail end of the trailer, and the longer the trailer the more problems you get. You might run into a problem scraping the tail end of the trailer on dips and curbs. It would be unfortunate to break tail lights, licence plate frames, and scrape the trailer. It would be downright TRAGIC if there is an outboard motor hanging too low off the back of that boat and you break the fin or lower unit.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
#4 | |
I've pulled some godawful loads with my pickups - some stuff I would never do again and never advise anyone else to even think about. I may not have always been able to hold 70mph on a long straight hill, but I always got up there and anyway most hills have curves that you have to slow down for anyway. These old Chevys have a lot of reserve built into them. The only problem you might have is pulling your boat up a wet ramp with 2wd and not much weight in the back.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
If you get an equalizer hitch you can adjust the rear of the truck and tongue of the trailer to make it level at all times. If you just address the ball mount, then the level of the trailer ball will vary when you load up the truck and/or trailer with items (such as camping gear,etc.)
You will be surprised on how much better your truck tows with an equalizer hitch. A new ball mount won't give you this benefit. The trailer wiring harness will hang down somewhat to accommodate turns and dips in the road. I have seen a lightweight bungee attached to the wiring with a short loop hanging down. The idea was that the bungee will give up slack when there is stress on the harness. I don't know if this is legal. 18 wheelers have flexible cables. http://www.easternmarine.com/15-abs-...sembly-30-9621 Also, check to see if you have trailer brakes if you have not done so yet. Just my $.02. |
Post Whore
Yep the bungee idea would work and give you some slack on wires when you turn..just make sure the wires wont pinch when you turn..on the tounge/hitch weight issue from the looks of it the boat is way forward on the trailer..next time you put it in the water don't winch it all the way to the front..leave the boat about 6" back from the winch..won't hurt a thing to pull it out on level ground and see what it looks like..if you like it just move the winch stand back to the boat..most trailers are a one size fits all design and you have some wiggle room as far as boat location on the trailer front to back..by no means get it to far back as to get to much weight off hitch..if you do you are asking for trouble..mine was all the way forward to and had about 350 lbs on the hitch so i kept moving it back until I got it where I wanted it..i moved mine about 10 1/2" and still have 200 lbs tounge weight
#7 | ||
Mine is about 8 inches back right now, not touching the carpet. I let the wife put the boat on the trailer lol. She's a big DIY'er and wants to do everything herself, at least once just to see if she can. So she wanted to put the boat in, and put it on the trailer and pull it out of the water when it was time to leave. She brought it up there to me with it like that. I went ahead and towed it home, but it definitely seems off balance. Trailer seems to rock up and down a lot more. The pontoons aren't hanging off the back, but they're right up to the edge of their resting place on the trailer. I was thinking of going to walmart or oriellys and getting some straps to strap the front of each pontoon to somewhere on the tongue of the trailer. Would this help? The fronts of the pontoons have tow hooks on them, so that wouldn't be an issue. I could just loop it around the trailer tongue. Whole thing kinda makes me nervous. |
That's a great looking truck, and rig when the boat is behind it.
I would urge you to look at trailer brakes. There is no way it stops as good with the trailer as without. You may not need them for regular traffic, but you may need them when a little kid isn't paying attention and walks into the street, or someone runs a stop sign going across the highway. If you are saying the trailer doesn't have brakes either, then you are likely stuck. Just make dang sure you drive extra defensively when pulling the boat.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Post Whore
Sounds like your boat may already be properly balanced on the trailer when you have it all the way forward,, especially if the trailer seems to bounce more,, you could tie down the front if you are concerned,, better safe than sorry,, but as long as the boat is fully supported on the bunks its not going to fall off.if your concerned about your truck squatting down it may be time for helper spring, load leveler, or airbag assist..the thing is the more you mash down on the back of the truck you are somewhat unloading the front tires making the front brakes less effective,,, but looking at the pics of your truck it doesn't look to bad,, I would just roll with it
#10 | ||
Ok cool I went to walmart and got some 500lb (1500 lb break rating) ratchet straps and put those on the front. They look a little small, but I don't see that boat being able to come up with 1500 lbs of upward force. Not just in normal driving down the road lol And thanks again for all the replies everyone, I can't thank you all enough for all the help. ![]() |
I don't think your pickup looks overloaded in the pictures (the boat is all the way forward there, right?). It looks to me like it is just settled down to the "loaded" level, like if you had some lumber or a camper on the back.
Generally, the more hitch weight the better, up until you unbalance the tow vehicle (back down, front up). I would invest in a weigh distributing hitch before I started moving the boat back on the trailer. They are not that expensive if you already have the receiver on your pickup, but it does take a little more time to hitch and un-hitch. I am surprised if that trailer does not have brakes on at least the front axle, as most manufacturers assume you are going to be pulling it with an inadequate vehicle. Some states require brakes if the loaded trailer is over 1500 or 2000 pounds so they have to be 50 state legal. Look underneath again, if there are no backing plates/drums on either axle then no, you don't have brakes. But I'm guessing the wires got chopped off, and you might have to take the drums off to connect them again. I've towed quite heavy trailers without brakes with a 3/4 ton, but they are designed to stop a lot more weight to begin with. I've also done it with a half ton without any big problems but it gets a bit more interesting. Also, a half ton with a four speed manual is quite a bit more capable holding things back on a long hill. Best thing would be to get your boat/trailer on a scale and know exactly what it weighs, and then make a rational decision from there. You might want to consider having brakes added to your trailer, or doing that work yourself. It shouldn't really be that expensive or hard to do.
Braking at highway speeds or downhill is where trailer brakes are most beneficial, in my opinion. I would agree with taking a closer look at the trailer for brakes - it would be unusual to not have brakes on at least one axle. It could be that they were just never wired up in the first place.
You can google trailer brakes to get an idea of what to look for. |
#13 |
I know that in NY, they go by unladen trailer weight as the line between a trailer that must have brakes and those that do not. When a trailer has an unladen weight of 1,000 lbs or more, it must have brakes in NY. Under 1,000 lbs, brakes are not required.
My Four Winns I mentioned before does not have brakes on the trailer, and it is the Four Winns trailer that came with the boat from the dealer. I just got home from a 10 day camping trip in the Adirondacks. With my '78, I towed my boat loaded with some gear, and also had the bed of the truck loaded with firewood, full coolers, and the heaviest Rubbermaid totes we take with us for the trip. My truck has the type of helper springs that come up against rubber stops when the truck is loaded down. It was on the helpers, but she did just fine.. ![]() I have to wholeheartedly agree with Tuscon about weight distributing hitches. I have a 27' camper and use them all the time when we haul the camper with the '06 Z-71 ext cab. And he is right, they do not simply and plainly raise the rear of the towing vehicle back up... they distribute tongue weight forward to the rest of the truck chassis, and back to the trailer axles. End result being a much more stable rig in every way to run down the highway when properly adjusted/set up. I hauled the camper a short distance (about 5 miles) recently with my K-10 (SWB). I hooked up, and was about to mount the torsion bars when I noticed the camper was slightly nose-up. I checked the rear springs and found that the helper were engaged and the truck didn't sit terribly low in the rear. I decided to go without the bars for the quick trip. It carried the weight just fine, and had adequate power to get it all moving. BUT, the problem I had and the reason I would not haul the camper long distance with the '78 was that camper being somewhat long and about 4500 lbs empty, in curves I could feel it wanting to sway and yank the rear of the truck around more than I was comfortable with. Granted, my truck is a short bed, reg cab, lifted 4" and has 35" tires..so not the best setup to tow heavier/longer trailers. Beside that, the old truck exceeded my expectations for toughness once again. ![]() I cannot even come close to hauling the camper without the torsion bars with the '06... She flattens right out, and bad. Looking at your pontoon trailer and going by the pics, I am not sure that you would be able to use torsion bars due to the design of the trailer tongue. You need an A-frame type tongue, like campers have. And on that A-frame, there needs to be open space to mount the torsion bar keepers, and clear space for the bars themselves along side the A-frame. But again, I do not see that rig being heavy enough to need torsion bars.. And it is very possible that it (the trailer) is light enough empty that brakes are not required (at least in NY) Couple of pics of my helper springs. Not sure what brand or if still available. They came on the truck when I bought it.
Who needs a Hemi when ya got a Chevy! |
