07-16-2015, 01:43 PM | #26 |
Re: Which grade oil should I use for my motor?
I run straight 30 in winter and 40 in summer. I just purchased the Zink additive and will be using it along with the new oil.
07-16-2015, 09:40 PM | #27 |
07-16-2015, 09:43 PM | #28 | |
Posted via Mobile Device |
07-16-2015, 09:44 PM | #29 |
07-16-2015, 09:45 PM | #30 |
07-22-2015, 01:48 PM | #31 | |
07-22-2015, 02:14 PM | #32 | |
07-22-2015, 08:21 PM | #33 | |
If you don't like this pound sand ..... |
07-22-2015, 09:20 PM | #34 |
The cam in that old six has very low lift and "slow" ramps. Combined with low pressure springs, there's no way you have to worry about flattening a lobe.
Sorry if I offend anyone, but I just don't get these ZDDP additives. You'd think we were talking about adding hotter salsa to a taco! Lubrication engineers and chemists spend a lot of time and money developing additive packages for their oils, and we're supposed to just dump in some ZDDP Plus and assume it blends well with any and all oils? Seriously? If your flat tappet cam lobe design and valve spring pressure dictate higher levels of ZDDP, then use an oil that has what you need as part of the additive package, like Driven Hot Rod oil. It ain't cheap oil, but it's cheap insurance. http://www.drivenracingoil.com/news/...ge-protection/ Good advice above from Chris at Shell, IMO. At least for a OE flat tappet cam and valve springs.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
07-22-2015, 09:40 PM | #35 | |
07-22-2015, 09:45 PM | #36 |
ZDDP was in oils 67-72 when these engines were built. Today, engines are different and they have roller lifters. Hence the oil specs have changed due to that and emissions regs.
That said, I've read that many additives added later wind up sitting at the bottom of the oil pan. |
07-22-2015, 11:10 PM | #37 |
Chris,
It's good to hear directly from Shell on the Rotella. As you're probably aware, there's a pretty large internet rumor that even Rotella has been reduced in it's zinc content. Are you saying that it still currently has 1200ppm? Thanks. |
07-23-2015, 03:16 PM | #38 | |
As for Walmart oil being good because it's Quaker State keep in mind these box stores are famous for inspiring confidence with a name brand but the item is made for them and based on a set price point.
`63 C-10 Shortwide Roller 305 LT1 cam, Eddy 500 T5 |
07-23-2015, 09:02 PM | #39 |
Thank you everyone for your replies, you all have very good statements. As of so far I am going to go with the 10w/30 Rotella and may also add a drop or two of ZDDP just in case if the rumor is true about Rotella Lol!!
07-24-2015, 09:19 AM | #40 |
Zinc/ZDDP is a "last ditch effort" type of lubricant. It really only comes into play after the oil film's strength has been exceeded. Too much ZDDP can be abrasive- that's why you find high levels of it in break-in oil, the engine breaks-in quickly that way. The best oil has a high film strength, and enough ZDDP as "back up" protection but not too much to be abrasive.
Oil thickness is determined by your bearing clearances. New/tight engines don't need thick oil. The bearings are cooled by oil FLOW through the bearings. Thick oil doesn't flow, especially through tight bearing clearances. Older/worn engines can use thicker oil since there is room for the oil to still flow. As for oil pressure, you only need 10 psi per 1000 rpm, so use thinner/thicker weight oil to adjust your oil pressure. Use as thin of oil as you can do you get the best flow and adequate pressure. Good info on film strength here. https://540ratblog.wordpress.com/201...-test-ranking/
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
07-24-2015, 09:24 AM | #41 | |
07-24-2015, 09:34 AM | #42 |
I've been using Valvoline VR1 in my '64 VW. It has a fairly aggressive cam with fast ramps. Each cam lobe has two lifters per lobe, so there's twice as much wear and only half of the time for oil spray to build up on the lobe (splash lubricated). The engine was broken in using Brad Penn oil, then switched to VR1 at approximately 5,000 miles. I swapped the cam at 27,000 miles and the lifters and cam lobes looked great.
07-24-2015, 10:05 AM | #43 |
That 39 psi, is that hot or cold? It won't hurt anything if it's higher than 10 per 1000 rpm. VW guys try to size the oil pump so that they don't make excessive pressure. When you only have 40-50 hp to start with you don't want a big pump making excessive pressure, it takes power to turn the pum and more power to turn a bigger pump.
07-31-2015, 06:43 PM | #44 | |
08-07-2015, 01:17 PM | #45 | ||
