#26 |
Re: AC Compressor Question
I can see in your picture that you installed a poa update kit. Whats your opinion on it?
#27 | |
#28 |
That looks nice. I have 2 stock condensers in the attic but when I do this I want to do it right and work well
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#29 |
#30 | |
If the cycling system doesn't work to my satisfaction I'll be putting the POA back on.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#31 |
Moderator
![]() Join Date: May 2007
Call to confirm, I'm pretty sure it is. There was a guy on here that converted to 134 recently and bought all the parts from old air.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#32 |
Old member
My setup is from Classic air.
http://www.classicautoair.com/ Very nice people to deal with and they know there stuff. I bought the Sanden compressor, brackets and hose kit with condenser for 134A. The tubes are bigger for more expansion so that the 134A will flow better. Thus helps with the cooling effect. I did away with the POA and drier altogether. I also closed off the outside cowl vent for better cooling inside the cab. My AC runs from 40* to 50* depending on how hot it is out side on 100* days it will be closer to 50* but any AC tech will tell you 40* difference is awsume. Mine will stay at the same temp sitting in traffic to. ![]() The kit I got! ![]() ![]() This picture shows the condenser that I installed. ![]() I did away with the old POA valve and dryer and added the accumulator. This last picture shows it since the 6.0 LS swap so the bracket has been changed out. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#33 | |
#34 |
It is tube and fin. Serpentine too.
The one in the add I believe they call it "piccolo" in this picture. The universal one I purchased looks like the one one the right. ![]()
#35 |
That's what I was thinking too. Good visual illustration.. That's why I was saying that I didn't believe the ones offered by old air products as a direct bolt on to be a parallel flow either. They look like that piccolo. Here is a pic of their condenser
#36 |
Old member
That's because the kit picture is a generic picture. It shows the dryer also. Which I don't have, it's a generic and they sell you the one you need, Da!
It's made for the 134A Freon. ![]()
#37 |
Moderator
This is usually the case...which is why people should call and ask. That will remove all doubt and answer the question.
#38 |
oh ok, I just thought what was in the pic is what one would get. Either way, neither one in the generic pic or the one on your truck is a true parallel flow condenser. At least not by the pic above showing the different types on condensers. But if it works then it doesn't matter.
#39 | |
Old member
![]() Quote:
My system works great! I was just putting info out for a swap that I performed back in the early 90 and has work with no problems since. ![]()
#40 |
If it's working for you nobody is complaining.
It's not the "expansion" that is important as we're talking about the "condenser". To condense back to a liquid we have to get rid of the heat. That is done with more contact area via the tiny tubes. Parallel flow lets the liquid to drop out while the hotter vapor to stay in the top of the condenser. Simply put, R134a requires more condenser than R12 to get rid of the heat otherwise pressures are higher and the system is less efficient.
#41 |
[QUOTE=Andy4639;7256425]I never said true parallel flow condenser for either one. I said they sold this one to me for 134a only with more and bigger tubes for expansion. I have no idea where you got the true parallel flow condenser part.
My system works great! I was just putting info out for a swap that I performed back in the early 90 and has work with no problems since. ![]() There was probably a misunderstanding. The discussion of parallel flow and where to buy started before you posted. That's where "the true parallel flow condenser part" came from. |
#42 |
Old member
Ok, that I understand. I was just saying mine wasn't. Just was making sure the info I put out was correctly took.
