Old 07-22-2015, 09:12 PM   #26
rharp
Re: Why is it so hard
That's the one
1969 Chevy CST/10 396, PS, PB, A/C
rharp is offline   Reply With Quote
Old 07-22-2015, 10:01 PM   #27
Mator
Mator's Avatar
How about these? Will 20x9 0 offset and 20 x 10 -19 offset work?
https://www.customwheeloffset.com/bu...-0-custom-rims
Mator is offline   Reply With Quote
Old 07-24-2015, 11:41 PM   #28
Mator
Mator's Avatar
So I found a good deal on Rocket booster 6's. But they only come in 20x9 with 5 back space and 20x9 5.75 bacspace. What's the best choice? Looking at 275/45/20.
Old 07-25-2015, 09:43 AM   #29
colgad
colgad's Avatar
Originally Posted by Mator View Post
So I found a good deal on Rocket booster 6's. But they only come in 20x9 with 5 back space and 20x9 5.75 backspace. What's the best choice? Looking at 275/45/20.
I would use the 5" Backspace ones (0 offset), you may need 1.5" spacers for the rear to get the rims closer to the outside of the fender for looks.
My rims are 10" with 0 offset and I would like more backspace in the front but the ones you are looking at are 9" and would give you .5" more clearance than mine (when you go to disk). The 5.75 backspace would give you 1.25" more clearance than mine.
If you are going to change to disk, in most kits it moves the spindle out .75" so the 5.75" backspace rims would offset (no pun intended) the addition of disk spindles. CPP has no offset disk kits by the way, then you could have all the same size rims.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 07-25-2015, 10:06 AM   #30
Mator
Mator's Avatar
Thanks. I was hoping someone could help. I start with the 5's and adjust the back as needed.
Old 07-25-2015, 05:56 PM   #31
colgad
colgad's Avatar
Make sure you check the hub size's. Hate for you to go this far and then they wouldn't fit!
Old 07-25-2015, 08:55 PM   #32
Mator
Mator's Avatar
Thank you. I think they are 106's but I will double check. That's what sucks about ordering online. I did call Rocket direct to check the fitment and they said I was good. But again I will doublel check. I had them quote the Nitto NT555 in a 255/35 ZR20 and a Toyo proxies st 275/45/20. What do you think? Thanks again.
Old 07-25-2015, 10:46 PM   #33
colgad
colgad's Avatar
275x45's fit good and fill the wheel well.
See how close the front are close to the wheel well opening
I would like to have an additional 1/2 or more.
Old 07-25-2015, 11:00 PM   #34
Mator
Mator's Avatar
Cool. Nice ride. That's awesome.
Old 07-29-2015, 06:04 PM   #35
Mator
Mator's Avatar
I forgot to ask, how much of a drop are you running? I pulled the trigger and ordered the boosters with the 275/45/20's all around.
Old 07-29-2015, 10:19 PM   #36
colgad
colgad's Avatar
I have bags all around so hard to say the exact drop but I like to run with the top of the tires at the top of the wheel wells most of the time.
looking forward to photos with the Boosters!!!
I installed a soft top on my Jimmy today, it was pretty easy. I just got the 5.3 running and may take it for a drive tomorrow, if the rain stops.
Old 07-29-2015, 10:46 PM   #37
Mator
Mator's Avatar
Wow, nice rig. Thanks again
Old 07-30-2015, 12:01 AM   #38
colgad
colgad's Avatar
Thanks, it's rust free but not very straight, I bought it with a bad 350 so I had a 5.3 and swapped it in. It will be just a runner for the beach, fishing and hauling around the grandkids.
Old 08-10-2015, 07:54 AM   #39
Mator
Mator's Avatar
Well, I pulled the trigger and they are in. What do you think. I think they are awesome. Rocket booster 6's 275/40/20. They were out of the 45's. and yes I have center caps.
Old 08-10-2015, 08:49 AM   #40
rharp
Those look great!
Old 08-10-2015, 09:00 AM   #41
jmking9
jmking9's Avatar
I think you made a great choice, they look very nice on your truck.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 08-10-2015, 09:13 AM   #42
clemsonteg
This is my truck with the Torq Thrust STs. They are the 19mm offset. To make them work I had to enlarge the hub bore and because I have the narrow 70 rear end and a 285 rear tire I had to add a 1" spacer on each side. I also have air bags so I needed a little more room for rear ended travel.
This is where I increased the bore size with a router and Rabbeting bit.
http://67-72chevytrucks.com/vboard/s...d.php?t=648787
clemsonteg is offline   Reply With Quote
Old 08-10-2015, 12:18 PM   #43
Mator
Mator's Avatar
Talking Re: Why is it so hard
I might have to add a spacer once I get the bed reinstalled. We painted on Friday night so we should be assembling it this week. I am trying to make a local car show on Saturday. I have a lot of work to get there though. Even if its only at 80% complete I will still have a blast. Thanks guys.
Old 08-10-2015, 01:10 PM   #44
bigmac73
bigmac73's Avatar
what paint color and brand is that , I am digging it but not trying to copy
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 08-10-2015, 01:13 PM   #45
Xeen
Xeen's Avatar
Yeah man 5-lug is really the only reasonable option, parts are easier to find, wheels are easier to find, it's just a win-win.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-10-2015, 01:59 PM   #46
Mator
Mator's Avatar
Thanks, its House of Colors candy HOK001125-01. I purchased from RRods. It really was comparable to price with most systems. It looks bronzy under fluorescent lights but a darker red in daylight. It almost seems to change colors. Thanks
Old 08-10-2015, 02:00 PM   #47
Mator
Mator's Avatar
I was able to keep my 6 lugs. just took a little more effort. Thanks though.
Old 08-10-2015, 02:08 PM   #48
Xeen
Xeen's Avatar
Ah yeah I didn't notice there was a second page.
Those are nice wheels and your paint is gorgeous!
Old 08-10-2015, 03:08 PM   #49
Mator
Mator's Avatar
Not bad for being painted in the garage. Thanks
Old 08-10-2015, 11:11 PM   #50
colgad
colgad's Avatar
The wheels look super! Good to know there are good 6 lug options out there!
I painted my red 67 in my garage too!!! ( not perfect but good enough )
