#26 |
Re: Defrost Turns the AC on WTH?!?!
I am going to get into it more today. Here is a blown apart pic of the system. Suggestions?
#27 |
Checkout the following thread: http://67-72chevytrucks.com/vboard/s...d.php?t=460942
It has lots of good info on fixing the heater core and related doors and flappers. To clarify my earlier post, your not connected vacuum hose probably should go to the vacuum pot that controls your recirculate door. Your post #11 has a better view of it behind the half dome. |
#28 |
Ok got to looking at old pics of the old motor. I see a difference in the way the heater core hoses are routed. In the original motor setup the pressure side to the core the hose was connected to the intake and then the return hose to the rad. On my new motor the pressure hose is connected to the water pump and return to the radiator. Could the fact that the pressure side hose being connected at the water pump now be causing a issue vs it being connect at the intake like the original motor. this has to be why I am getting a dribble on the return side to the rad. When I get home I am fixing this and testing.
#29 |
Hmm
#30 |
#31 |
This thread seems on point for your hose routing question. The OP had his like you do with similar results.
http://67-72chevytrucks.com/vboard/s...d.php?t=559186 My 75 has connections from the intake and returns to the radiator. |
#32 | |
#33 |
Old. Hose in intake.
#34 |
New. Hose in water pump.
#35 |
78K & 79C Jimmys
any leak it won't close outside air
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#36 |
That helped me and I'm not even working on my AC...yet.
#37 |
#38 |
Actually I am missing all of the Kick Pad Valve assembly. Now to hunt them down. Something else on the list lol. Which I have not seen those in any catalogs I have.
#39 |
Completely Normal for the A/C to be on with defrost, its designed that way.
I'd check to see if your heater hoses are even getting hot. And obviously the truck has to be at operating temperature. |
#40 | |
78K & 79C Jimmys
88 shown
#41 |
#42 |
Got heat. Took hose from water pump put on intake got heat lol. I looked at old pics of motor and my new setup over and over and over and it was right in front of my face. Took me a couple of days had to order a fitting. Works great! Thanks for all the help.
#43 |
Thumbs up
#44 |
I wish I would have seen this thread earlier!!! Same thing happened to me when I changed around my 350 last year. Glad you got it settled!
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
