07-27-2015, 05:02 PM | #26 |
Re: Flawed Success Turn Signal Puzzle
Ehh??
The flat blades at 2:00 and 4:00 are most useful. You have to look inside the connector to see the terminal locks. Hold it up to the light to see inside. Look for Youtube videos on releasing terminals |
07-27-2015, 07:17 PM | #27 |
OK. I figured it out. Wasn't holding my mouth right...
Posted via Mobile Device |
07-27-2015, 08:47 PM | #28 |
Does it matter what collar the wires come out of? I am having no luck getting them down to the lower collar where the previous wires emerged from.
Tire Guy ---------------------------- Yep I'm a Corvette Guy... 2014 Corvette Stingray 1957 Chevy 3100 |
07-27-2015, 09:36 PM | #29 |
It can make a difference where the wires exit. Without being there to see the column it's hard to say but I'd duplicate original routing if possible. Did you get a string through there? Are the wires hanging up because they are one big clump? You can tape the wires so all the terminals are not grouped together in one big ball or clump. Tape a few together, then a few slightly higher up. Ir if you have a string tied to the terminals and they are hanging up you can tape the terminals to the string to help. There's usually plenty of room once you have it installed correctly.
07-27-2015, 09:55 PM | #30 | |
3 wires on the harness are damaged. 1 completely torn through. There are all kind of parts rattling around under the shift lever. So much so that two springs fell out of the column. I also am having trouble getting the shifter from reverse to drive and back. Something is really wrong. Crap crap crap. Now to rebuild it or just by a new one and move on.
07-28-2015, 05:44 AM | #31 |
post deleted
Old Crow '54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ |
07-28-2015, 09:59 AM | #32 |
Now that I have disassembled the entire column I can see that there was NEVER any way for the wire bundle to feed through its designated route. There is a shield at the bottom that is just wide enough and deep enough for the wires. Nothing was damaged beyond repair so it is just a matter of putting it all back together.
I gear shifter is just apart and easily put back together except I am confused on the placement of the 3 springs that fell out. I see a place for one but not the other two. Anybody have a diagram or video reference. I am looking on youtube but nothing so far.
07-28-2015, 06:29 PM | #33 | |
Here is a thread with pictures of a tilt column: http://67-72chevytrucks.com/vboard/s....php?p=2118640 and a non-tilt from the same era: http://67-72chevytrucks.com/vboard/s...d.php?t=366986 HTH |
07-28-2015, 07:46 PM | #34 | |
I checked the links you provided and those aren't what I have. So today I took it apart and reassembled with a new switch and everything is going well except I can't get the bearing assembly down the shaft far enough to put on the retaining clip. So I am stuck until I figure this out. Pictures below of the shifter plate then the bearing assembly.
07-29-2015, 06:51 AM | #35 |
Sounds like you need to lock the BFH's up until this project is done!
Picture of non-tilt assembly, top picture in link#2 above, looks like same stuff to me. Preload spring #19 must be compressed to install lock clip. The shaft has to be pulled up to do this. Later columns are different but there is a tool that might work for this job called a lock plate depressor. Search for it and you can find several different versions. Looks like you've got the turn signal bucket support plate #35 on already (the housing with the bearing inside) but the bucket is supposed to be installed first, then the support. The bucket gets sandwiched between the support and the shifter detent. I did find a little video that might help. This guy has torn his column apart and is describing how it goes back together so he can remember later. https://www.youtube.com/watch?v=it7cQuRVun0 |
07-29-2015, 08:17 AM | #36 | |
07-29-2015, 11:21 AM | #37 | |
07-29-2015, 12:36 PM | #38 |
07-29-2015, 12:47 PM | #39 |
07-29-2015, 02:54 PM | #40 |
I have found a company that will make me a 1/2 x 20 to 9/16 x 18 adapter so this lock plate compressor tool will work. Cost is $40.
Anybody have any other ideas?
07-29-2015, 03:38 PM | #41 |
Buy the tool, get a nut that fits the shaft, apply welder?
There are many different brands of tools. Some may have different ends? Slide snap ring over shaft, thread nut onto shaft, use pry bar to gently lever shaft up then slide ring down into groove? Last edited by 1project2many; 07-29-2015 at 03:54 PM. |
07-29-2015, 03:50 PM | #42 | |
I thought the same thing about welding another piece on but I don't have a welder or access to one. Maybe one of the local shops may do it for a reasonable charge.
07-29-2015, 04:54 PM | #43 |
I got the local tire shop to spot weld a 1/2 inch on the end. No cost. I use to sell them tires. I'll let you know how it works.
07-30-2015, 03:14 PM | #44 |
OK, after a long learning experience with the steering column it is all back together. Shifts and steering correctly, turn signal switch is in all wired correctly.
So back to my original problem, turn signals and brakes all flashing all the time. And just as somebody posted might happen, NO CHANGE. Ugh. As Orge posted I think I will rewire to the correct schematic and remove any by-passes that I have done. Then work my way through the rats nest of the wiring harness and chase the wiring to each component. Thanks for the help getting me through the steering column mess I created. Least I know how it all works now so when I do replace it with a new unit I will be better prepared.
07-30-2015, 03:26 PM | #45 | ||
Those jumpers you installed provide a permanent connection from RH light to LH light. With brake and turn on the same "bulb" you have to wire it like the factory diagram. The brake wire is connected to both bulbs through the turn signal switch when the turn signal is "off." When you select a turn, the turn switch disconnects the bulb from the brake light switch and connects it to the flasher. Although the diagrams all look different, this thread has several wiring diagrams that show the same circuits. Connect the brake light switch to the turn signal switch white wire and the flasher to the brown wire. |
07-30-2015, 03:55 PM | #46 | |
07-31-2015, 01:49 PM | #47 | |
07-31-2015, 02:44 PM | #48 |
The brown wire connects to the hazard / emergency flasher. Ppl is turn flasher. Should have specified that.
07-31-2015, 02:45 PM | #49 |
Just fixed the emergency flashers. Getting closer.....
07-31-2015, 08:29 PM | #50 |
Partial success:
I redid the wiring to match the correct schematic. Put in the missing wire for the emergency flasher that was not there and rewired the flasher correctly based on the schematic. So everything was as it should be and it made NO change. Everything flashes. So I started to work backward: Removed the new turn signals. - No change (hooked back up) Redid all the grounds - No change Removed the brake lights - no change (hooked back up) Removed the wiring for the tail lights - TADAA! Without the tail light wire the rear brake lights and turn signals worked perfectly, but every time I applied the wires anywhere in the mix they all started to flash again. Tomorrow I will work through the tail light wiring. The other issue is the both front turn signals flashed together even when the back were working correctly. So today was a positive. Thanks 1Project2Many for your help.
