#26 |
![]() Join Date: Jul 2012
Re: My first project... 1968 GMC lwb fleetside
Nicely done!
#27 |
I made some major progress this week. I finished the exhaust pass through on the driver side and it looks freakin amazing!!! Next order of business was to fix a major bend in the frame behind the rear axle. What it was was a pack of leaf springs bolted to the frame as a form of overload or helper springs and they bent the crap out of the frame. Sooooo the plan was to chop the last 2.5 feet of frame off and weld the good portion from my other parts truck back on. My slice and dice worked well. I was so pumped with the fitment. Everything is square and straight. I just haven't fishplated it yet but looking good to take it to the sandblaster by the end of the week.
My 68 Build http://67-72chevytrucks.com/vboard/s...=1#post7272324 Herb! My C30 build http://67-72chevytrucks.com/vboard/s...80#post7304180 |
#28 |
Looking great
#29 |
Also, I brought my motor and tranny to the shop where I'm working on the frame. Today was an expensive day, I bought $400 worth of tools. Beauty eh?! Got me an engine lift and leveler and a good arsenal of clamps for the frame fix. Anyway, got the engine sittin pretty in the frame and checking for clearances. My engine stand clears the headers and I patched the frame on the driver side header notch. I was also checking drive train angles and I measured my engine and trans to be 6*. Now I'm kind of a noob but I've been reading around and everyone says max angle is around 4*. Any recommendations on how and where to shim the trans up?
Just curious what would you say the engines milage is based on how the heads look?!
#30 |
Under Construction
nice progress....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#31 |
So today I fabbed up my fishplates for the frame repair and after work I got my pops to help me lay the floor onto the frame to check for trans clearance. Everything clears with inches to spare and looks freakin amazing to boot. Everything is now officially ready for sandblast hopefully tomorrow
#32 |
Today was good. I hit the junkyard this morning and bought me a power steering box off of a 73-74 C20. I thought that the boxes from this year would still be imperial with a flare fitting but the box I picked up is a metric one with an o ring fitting. This should be a bit better because the LS pump is metric as well so should be a bit easier to figure out the lines. The rad support bracket needed a bit of clearancing to fit the box but overall the install is pretty bolt in. Now all I'm wondering if I need the centerlink off of the donor truck in order to make it all work or if I can use my 68 drag link.
#33 |
following! i have to do the same frame repair for my c20 as my auxiliary leafs springs rotted a hole where my trailer hitch would mount.
#34 |
I had a few days off this week and got the frame sandblasted and coated. Also finished up fishplating the rear section. I ended up using a POR15 like coating. IT's KBS coating which I think is just POR re-branded. It layed down really well but brushing it on was a PITA. It took me a whole day to coat the whole frame but it was definitely worth it it looks great. I got all the other parts coated as well and re assembly will begin on the weekend. I still need to find a rear end and fab up a set of trailing arms then she'll be a roller.
#35 |
![]() Join Date: Apr 2008
Nice work- looking forward to seeing it progress!
#36 |
Your making great progress, ya know in your first post it sounded like being a student you didn't have a lot of experiance at this stuff so some folks natural instinct is to tell people not to tare it apart cause it will forever remain a project, but your showing us otherwise!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#37 | |
Yesterday I put mounted the front and trans crossmember, steering box, pitman, idler, centerlink, and my gas tank. It's starting to look super good. Ive got all my a arms spindles and brake parts painted but I cant put them on because I've got no bushings to put the a arms together. No place has them in Winnipeg so I'm kinda stuck for a bit. Oh well
#38 |
If ya havent ordered yet maybe order thru a place like Rockauto.com?
#39 |
I think I will because part source or canadian tire wants $100 a shaft kit. Insane if you ask me. Think I'll order them tonight.
#40 |
It's been a while since the last update mainly because I was dead broke for the past 2 and a bit weeks. Anyway I started fab of the rear trailing arms then I ended up drilling a hole wrong and that sidelined that for a bit. Decided to practice my welding skills and built a bumper for my buddies 95 truck . Had it CNC'd a couple of years ago but I never had a welder to finish it.
Anyway, I started painting the engine and trans on monday and just bolted it all up today. It turned out friggin awesome ![]()
#41 |
trail arms look similar. I made these from 2x3x3/16 tubing. I also found some bushings body mounts and other stuff through autopartsway.ca
#42 |
Looks great! Cant wait to tear apart my 71 GMC!
1971 GMC Sierra Grande 2500 2wd "Sadiee" Caddy 472/TH400 Project "Sadiee" 1969 Chevy C/10 Build "Maisie" Thread coming soon |
#43 |
Yeah I liked your design so I thought I'd try my own. The hardest part was cutting the mitres just wondering how you ended up doing it. Thanks for the info on the bushings. I hate trying to find the little stuff in canada.
#44 |
I found it had a 15 deg kick up so I did some lay out on my table to get that angle. I set my angle at 12.5 deg because of the lowering. Then I don't need a pinion shim. I left the bottom uncut, cut the notch with a 5" quick cut then bend the end up. I drilled the holes through and welded tubes inside, added E brake clips and sway bay mounts.
#45 |
I am really liking the color combo on the engine and trans. Looks good.
#46 | |
Thanks! I'm stoked at how it turned out
#47 | |
#48 |
Thanks and by the looks of your skills these shouldn't be to bad to make. Make sure you have 100% penetration welds. I did the same mod for the steering box. Keep it up man it's coming along great.
#49 |
Thanks! Yeah I agree, shouldn't be too bad.
#50 |
Yesterday evening swapped the ammeter out for a 73-87 voltmeter. I tried fitting the donor one in but the needle is a bit short and I couldn't see needle or the scale. So I drilled the rivets out of both faces and the removed the needles. The old face fit perfectly on the newer gauge then I just jb welded it to the newer gauge. Needle fits the same as the newer one and looks good. Havent tested if it works or not but this isn't the last mod that I'll be doing to the cluster.
Also today I bolted the intake and everything on top on for the final time. Looks pretty good imo but I kinda wish it was a holley midram but thats not in the budget yet ![]() This past week has got me pretty pissed with how slow paypal processes debit transactions. It's been a week since I ordered from rockauto and my paypal deal still hasn't gone through so no front end parts for a while ![]()
