Old 08-01-2015, 08:28 PM   #26
hamjet
hamjet's Avatar
Re: Hot Rod farm trucks and similar sleepers
Originally Posted by SpaceTruckin View Post
Im in love with that blue gmc! The bed is cool, never seen skirts on one of these trucks
I believe those boxes were made in mexico...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 08-01-2015, 09:16 PM   #27
Bucket of bolts
The way I look at it this is what old trucks are all about.Good old SBC tuned up.No vortecs or LS7 or 17 inch disco rims .Just good runners with detail and pride. CREPPING DEATH prime example
Bucket of bolts is offline   Reply With Quote
Old 08-01-2015, 09:19 PM   #28
Bucket of bolts
Hiccup, more beer another photo
Old 08-01-2015, 10:30 PM   #29
ViviensTractor5110
Well put. Working man death machine. I'm glad I started this madness.
ViviensTractor5110 is offline   Reply With Quote
Old 08-01-2015, 10:31 PM   #30
ViviensTractor5110
Tickled to death to see it take off.
Old 08-01-2015, 10:32 PM   #31
sbc10guy
sbc10guy's Avatar
Here is my 69 shortbox. Has a mildly built 454 with a muncie m20 and 4:11 posi. I like when people ask me if it runs. It not only runs but it tears up the neighborhood pretty well too. Alot of fun to drive and i dont have to worry about door dings.
1969 shortbed c/10
1998 GMC sierra
sbc10guy is offline   Reply With Quote
Old 08-01-2015, 10:34 PM   #32
cericd
cericd's Avatar
Originally Posted by Heavymetl View Post
So far ran 11.48@116 in the 1/4, 7.28@94 in the 1/8th, on only 10lbs of boost.
Drives like a stock truck, the turbo does all the work. Probably the most fun vehicle I've built or owned!
Love this truck!!!!
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 08-02-2015, 07:01 AM   #33
68C15
blood type; Retumbo
68C15's Avatar
I've spent many a times just wondering about my 67 short step. How hard would it be to put a newer 6 speed auto behing my 472 caddy. just think, 6 areas of double rubber on the road.
I have only had one sleeper in my life. I took the 475hp SBC from my 80K20 and put it into an 84 Cutlass 4 door with trailer hitch, rusty doors and all. The 2800 stall convertor and 2.14 gears made it a real freeway burner. It would pass everything except Illinois emissions test.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-02-2015, 08:38 AM   #34
dirtyjim
dirtyjim's Avatar
these were a few farmtruck type sleepers when I was younger, but they were only sleepers if you didn't hear them running. the best two was a white mid 80's ford extended cab with a 351, very big solid lifter cam and a 250 shot of nitrous. I seen it run high 11's with 31" mud tires on the back. the other was a mid 80's blue chevy c10 with a nitroused 454, the main difference between it and the ford was that it was quiet and the ac still worked. the guy used to run it down the street with slicks on the back and since they were on rally rims with caps and rings that matched the front most people didn't even notice. he also towed his chevelle race car with it, chevelle ran low 9's truck on spray ran mid 10's
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 08-02-2015, 12:48 PM   #35
darkhorse970
darkhorse970's Avatar
Subscribed
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 08-02-2015, 01:43 PM   #36
1972RedNeck
1972RedNeck's Avatar
I think I've got ya'll beat in the farm truck category.
But, it has a stock 350 out of a 1976 pickup (which was one of the lowest performance 350's ever produced) so it's anything but fast.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-02-2015, 07:40 PM   #37
LMREESE
This is Ol' Blue. I just set the removable welding skid on to go weld a broke hay mower. The welder is a 1954 lincoln shorthood. The specs are 350, bored .40 over, double hump heads and a granny 4 speed.
67 C10 swb bored out 350 granny 4 speed
I come from a long line of moonshiners
LMREESE is offline   Reply With Quote
Old 08-02-2015, 09:42 PM   #38
Steeveedee
Who Changed This?
Steeveedee's Avatar
Nice lookin' bunch of hot rods!
Mine's not exactly a sleeper; it says "400" right on the fender, and it surprises some people both in town and on the freeway, since it isn't quite stock. I'm thinking of starting up a woodworking shop now that I have retired. I'll need a truck (and it won't be a "newish" truck; I'm thinking early '60s step side). Of course, it will be all "faded" paint and such. It just depends on how much time I have. I also have a couple of hot rod Buicks to sell off before I get there. That ought to help the financing. We will see where that pipe dream leads.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 08-02-2015, 10:07 PM   #39
ViviensTractor5110
Steevee- tell me about your 400...aside from an oil leak from hell (which I spend most of my time trying to locate- not a pleasant thread but there is one on it) I'm tickled to death with mine. Runs cool, starts easy....more torque than I need...stock displacement 2 bolt splayed mains hv oil pump 750 edelbrock/rpm airgap rv cam....a lot of ass for not much hardware. Cams small enough to not dick with my vacuum but still sounds insane. It's not running 10s on bias plys and a sm 465 but It runs on children's tears....and that's all that matters.
Old 08-02-2015, 10:10 PM   #40
ViviensTractor5110
LM- it's heartwarming to see I'm not the only short half ton flatbed running about. Nice job.
Old 08-02-2015, 10:21 PM   #41
LMREESE
Hey thanks! Me and Ol' Blue have been together my whole life. My grandpaw bought it new and I bought it from him when I was 12. I've got the pickup box put up in the barn. I make my living with the truck and the flatbed serves me better. I'm a farrier and I have an aluminum body with all my horseshoing tools in it that sets down on the flatbed. It has one ton springs all the way around so heavy loads aren't a problem. That welder weighs 1350lbs.
Old 08-03-2015, 02:58 PM   #42
kelz702
Originally Posted by Blakeman350 View Post
What kind of fuel regulator are you running?
Sorry for the late reply. I was up in the mountains camping and fishing. My buddy gave me that regulator. The regulator and pressure gauge both say Jegs on them. I set it at 5.5-6 but the gauge reads all over the place. It doesn't seem to be causing any problems so I don't mess with it.
kelz702 is offline   Reply With Quote
Old 08-03-2015, 03:12 PM   #43
NC_John
NC_John's Avatar
325-350 hp, tremec 6-spd, 4.56 posi rear end. Not sure how fast it is yet- I am impatiently trying to bed in the brand new ring and pinion. And its a sleeper (even under the hood) unless its running. Gonna target 500 hp the next time I crack it upen with some more go-fast parts.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 08-03-2015, 03:51 PM   #44
Blakeman350
Blakeman350's Avatar
Thanks for the info
Blakeman350 is offline   Reply With Quote
Old 08-03-2015, 04:08 PM   #45
Lattimer
Lattimer's Avatar
Nice. I need a set of wide wheels like you have on the back. I want to go back to the dog dishes but haven't been able to find any 8" wide wheels.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 08-03-2015, 04:37 PM   #46
98Murray
98Murray's Avatar
1985 GMC High Sierra 2500. 454 BBC with a 4 speed, 2WD. She'll tow any trailer out there and pass anything on the road except a gas station.
98Murray is offline   Reply With Quote
Old 08-03-2015, 04:53 PM   #47
SeniorVerde
SeniorVerde's Avatar
Now this is a thread I can relate to!
Leaving it just like that on the outside,
.30 over 454 and Th400 with a gear vendors, 9" rear on the underside.
SeniorVerde is offline   Reply With Quote
Old 08-03-2015, 05:04 PM   #48
doo142
doo142's Avatar
I like them stock but this is a blast to drive and catches ALOT of attention. 454, tremec t56 6 speed
doo142 is offline   Reply With Quote
Old 08-03-2015, 05:06 PM   #49
doo142
doo142's Avatar
One more
Old 08-03-2015, 05:58 PM   #50
CST10
CST10's Avatar
Here's ol Samson. 462 CI putting down 445HP/490TQ. Brutus the camaro in the background too.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
farm truck sleeper
