09-11-2015, 11:42 AM | #26 |
Re: 71 LWB Frame For Parts
Yeah see 25 for a frame but shipping be 35-40$. I got a wt and rough guess on box size.
09-11-2015, 05:17 PM | #27 |
"uncle" - I can do $25 for the drivers lower control arm if it is in good shape. You know, no wallowed holes etc. Mine is bent pretty bad. PO must have hit a culvert or tree stump.
Lets see if we can get the shipping lower please. Do you think it would fit in a US Postal Priority mail flat rate box? Are you familiar with those? There is a large size (12" x 12" x 5-1/2") for $17.90 and a medium size (11-7/8" x 3-3/8" x 13-5/8") for $12.65. Do you think that arm would fit in one of those? Weight doesn't matter when you use these boxes. If it fits in the box, weight is no concern. Thanks for checking! |
09-11-2015, 06:24 PM | #28 |
A-frame not close to fitting in flat rate. I measured a-frame and added 1" to each dimension and 1 lb for box and packing and it was $36 on USPS website.
09-11-2015, 07:09 PM | #29 |
OK. Thanks for checking. I am going to send PM.
09-11-2015, 07:38 PM | #30 |
pm for the 71 center drag link....
09-12-2015, 05:17 PM | #31 |
do you happen to have the rear leaf spring hangers in good shape?
09-13-2015, 01:36 PM | #32 |
This is cool spring truck.
09-16-2015, 11:36 AM | #33 |
Bump. Coil spring.
04-24-2016, 03:25 PM | #34 |
Hello, do you still have the frame tails? I am in need of some, please see the attached thank you.
1971 K10 SWB -Bryan B.- |
04-24-2016, 03:53 PM | #35 |
Still have it. How much you need? I will warn you that shipping will be high, may be better to get some closer to you.
04-24-2016, 07:25 PM | #36 |
Uncle, I went out and measured it. The last 24" of the left and right frame, that should keep down the shipping as well. What are you thinking about pricewise?
-Bryan B.- |
04-24-2016, 08:00 PM | #37 |
$20 plus ship.
04-24-2016, 09:26 PM | #38 |
Ok, sounds good to me. How do I pay for the item, shipping etc? Thank you.
-Bryan B.- |
04-25-2016, 07:48 AM | #39 |
Won't know shipping till removed.
04-25-2016, 08:48 AM | #40 |
04-25-2016, 04:01 PM | #41 |
Beanies what's your zip
04-26-2016, 02:35 PM | #42 |
05-13-2016, 03:35 PM | #43 |
Hi,
I am wondering if you happen to have, or would cut a couple of frame sections. I need a section a couple of feet on either side of the rear spring perches. For both the left and right frame rails. The truck is a 71 C10 (2wd). Also the top spring mounts if you have a set. Thanks! |
05-13-2016, 07:42 PM | #44 |
Can you get a pic of what you need?
05-13-2016, 08:03 PM | #45 |
Hi Uncle.
I have need of left front frame where the power steering pump mounts> From the back of the frame about 4 inches where the pump mounts to the front of the frame. |
05-13-2016, 08:08 PM | #46 |
Give me a zip and will try to get quote over weekend. Try to shoot you a pic tomorrow of what I think you're talking about .
05-13-2016, 11:02 PM | #47 |
got the frame mount for the tracking bar? to 47224
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
05-14-2016, 03:25 PM | #48 |
Covingtontn isn't this long enough? Do you need rad support mount with it?
05-14-2016, 03:26 PM | #49 |
Bbbbbbbbbbb
05-14-2016, 03:27 PM | #50 |
Jamie 72 I think I have one off. Give me couple days to find it.
