08-08-2015, 05:56 PM | #26 |
Re: Another piece of the puzzle showed up.
Wow, nice collection, I need that 5 bladed flex fan!!
08-08-2015, 07:10 PM | #27 |
08-08-2015, 08:40 PM | #28 |
Thanks LT1 ! That one in the pictures turned out to be a passenger car blade. If you look in the 67-72 parts section , 67 fans are the same for our AC trucks. That's where I was able to score one.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
08-09-2015, 07:31 PM | #29 |
he ya go, needs wholes welded up and redrilled.
08-09-2015, 07:32 PM | #30 |
backside
08-14-2015, 09:49 PM | #31 |
My latest prize just showed up, an NOS low hump mat.
Posted via Mobile Device |
08-14-2015, 10:04 PM | #32 |
08-14-2015, 10:22 PM | #33 |
Holy grail. Where did you locate that piece of the old west?
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
08-15-2015, 10:44 AM | #34 |
08-17-2015, 10:52 AM | #35 |
So I was at a buddy of mine in Canada and he is into 32,33 fords. I was checking out his garage and I see this out of place chevy fan hanging off the rafters. So I now have it but what are the chances, Canada been good to me this time.
08-17-2015, 03:49 PM | #36 |
Great score!!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-17-2015, 10:37 PM | #37 |
very nice, hope it was free!!!
08-19-2015, 09:52 AM | #38 |
08-19-2015, 10:21 AM | #39 |
ok, i'll toss it. i found this combo as well. cheap of course!!! its not round rivets, but it does have the "H" on it and "FRONT" so im happy. the last clutch had K10 on it, but when i had it gold zinc plated i almost cried, cuz the acid dip just killed it.
08-19-2015, 10:44 AM | #40 | |
Shows an NOS Clutch and the correct 65-68? Truck only fan blade. When I get back Sat I will post measurements .
08-19-2015, 10:59 AM | #41 |
again the master has spoken, id hate/love to have you judge our trucks for pre-show inspection!!!
08-19-2015, 11:26 AM | #42 |
Sorry guys, the fans you both have will work fine. It's just that this correct stuff to me means something when you're trying to preserve a truck. Had I not joined this website, I never would've known the difference either. But I have learned so much on here and it's challenged me to learn Also.
08-19-2015, 07:07 PM | #43 | |
Can you post a measurement 60-66 , thx for the info. |
08-19-2015, 07:11 PM | #44 |
08-24-2015, 02:10 PM | #45 |
OK Guys , heres a few different clutch fans. Of the 5 black fan blades there are 4 different styles , two different round rivet and two different flat rivet styles ( there are still a few different blades out there). These are all for Cars , Camaro Chevelle Nova Corvette. Some with 4 rivet which are said to be low performance 283 327 and 325 HP 396. The 5 rivet style is said to be more for Heavy Duty applications and Higher horsepower cars. Theres one or two rare High performance fans I do not have. What these ALL have in common is they are 60-68 Short water pump 18 inch 5 blade fans . There were some of these early round rivet fan blades used on our trucks from 1960-1963 maybe 1964 with AIR Conditioning. These fans were sold as accessories also and could be dealer installed.
The bottom orange fan is the correct 65 66 Factory AC fan blade for trucks. Looks very similar to the one on the top right. The difference being the truck has a larger clutch , larger hub and bolt pattern for the clutch to bolt to the blade. The bolt pattern on the hub to the water pump is the same. The black blades all have a center hole diameter of 2.375 and a hub dia of 2.335 . The Orange truck blade has a hole diameter of 2.625 and a hub diameter of 2.575 . Physically the truck clutch is larger than the Car clutch also. Blade Diameter remains 18 inch. These are all factory Chevrolet blades and clutches with the exception of the top center clutch, some Schweitzer clutches and some Eaton clutches. Of the two bottom clutches next to the orange blade, these are both Eaton but slightly different designs.
08-24-2015, 02:30 PM | #46 |
How come the blades are not spaced evenly?
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE |
08-24-2015, 02:37 PM | #47 |
08-24-2015, 02:47 PM | #48 |
Here's mine
08-24-2015, 02:48 PM | #49 |
Clutch
08-24-2015, 02:51 PM | #50 |
Eaton
