08-12-2015, 10:10 PM | #26 |
Re: Where can we find brass and copper heater cores?
got mine on ebay...took a lot of emails ad calls.
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
08-12-2015, 10:35 PM | #27 |
Bummer. I'm still not sure why they would, and I'm somewhat fanatic about original parts. The aluminums are bad?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-13-2015, 01:26 AM | #28 |
Moderator
I used an aluminum heater core from oreillys. Air gets hot (although I rarely need it) and it doesn't leak. Been a few years now, I'm not concerned about it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-13-2015, 08:46 AM | #29 |
Just thought I'd throw in a bit of potentially positive news. I've been searching for a replacement heater core for my '72 with A/C and found an APDI/PRO unit on Rockautos website. The P/N is 9010121. The picture showed it being a copper bodied unit. I contacted APDI and the tech support person verified it is a copper unit.
I guess I should have asked if they have a non-A/C copper unit while I had him on the phone but didn't think of it until I started writing this post. If anyone wants to discuss with APDI, their number for tech support is 877-375-3954. Happy hunting. |
08-13-2015, 01:30 PM | #30 |
No matter what metal is used, changing coolant every couple years helps eliminate a whole lotta problems. Old coolant gets pretty corrosive, and not just the radiators or heater cores get damaged, everything it touches is a candidate for brutality.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
08-13-2015, 11:31 PM | #31 | |
And it's not as though the BBC has trouble producing heat. At least not mine anyway (no extra fan).
08-13-2015, 11:34 PM | #32 |
I use distilled water, and the overflow is always clean. That said, last time I flushed the system, so of course tap water was left over. On topic, I wonder how much water is left over with the radiator drained?
08-14-2015, 01:10 PM | #33 |
I can tell you, one things for sure, none of them, copper or aluminum, fit like a Harrison!
08-14-2015, 01:16 PM | #34 |
You are correct F.A.A.BENNY.
08-14-2015, 10:28 PM | #35 | |
Happy |
08-15-2015, 12:39 PM | #36 |
An interesting read, and quite relevant.
http://www.caparadiator.com/aluminumvscopper.html Regards, Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
08-17-2015, 08:07 PM | #37 |
I got an extra brass/copper heater core from my '72 build that's for an a/c truck, if that's what you need.it's in great shape and yours for the cost of postage......let me know.
Ben Smith |
08-18-2015, 11:23 AM | #38 |
Outback truck parts in Houston,Texas look them up Family owned and operated you won't regret it.
08-18-2015, 01:31 PM | #39 | |
08-19-2015, 05:53 AM | #40 |
My brass and copper is a vista pro radiator. Fit is great and 4 core.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
09-08-2015, 08:55 PM | #41 |
here are a few pictures of the original brass and copper heater core I have.......
Ben |
09-08-2015, 08:56 PM | #42 |
hope this is what you are looking for!
Ben |
09-08-2015, 09:03 PM | #43 |
I'm all in for that Pepsi can't go wrong with a ice cold Pepsi
09-08-2015, 09:22 PM | #44 |
This thread has indeed produced!
My local radiator shop found me one that is all copper. I haven't checked it for fit yet but I saved the receipt. |
09-09-2015, 02:34 AM | #45 |
[QUOTE=snipescastle2;7302743]here are a few pictures of the original brass and copper heater core I have.......
Ben [/QUOTE Ben, that's not an original heater core. That's an aftermarket one. The factory originals were Harrison heater cores |
09-09-2015, 12:26 PM | #46 |
Okay, it's a brass and copper heater core, at least it's not aluminum.....sorry for the confusion.....
Ben |
09-09-2015, 12:28 PM | #47 |
Ok, well, it's boxed up ready to go, if you change your mind.
Ben |
09-10-2015, 11:43 PM | #48 |
Looks good to me
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
09-11-2015, 01:53 AM | #49 |
09-12-2015, 04:03 AM | #50 |
should be heading my way as we speak
