Old 09-03-2015, 01:12 PM   #26
yoshi
yoshi's Avatar
Re: Sorting suspension out
Not sure as it says GM metric calliper adaptors, mine is all mustangll except the bolt pattern
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 09-03-2015, 03:44 PM   #27
yoshi
yoshi's Avatar
This is the old one mocked up
yoshi's 49 project
Old 09-03-2015, 03:45 PM   #28
yoshi
yoshi's Avatar
This is the new setup but only 1 bolt is in place
yoshi's 49 project
Old 09-03-2015, 04:25 PM   #29
oldman3
oldman3's Avatar
Yoshi, don't mean to muddy up this thread, but need to see if we can clear up some items. You stated yours was all mustang II. Mustant II came with only 9-1/4" rotors and very small pad about 1-1/4" X 5". Here is a pic of when I changed my original style MII rotors to the lager GM on my 32 Chevy in 89-91 years, you can see the difference. (GM on the left and MII on right. ) Your adapter is also aftermarket. MII was different. Yours looks like a forged piece and now most are flat steel, etc. Your calipers appear to be GM metric, uses bolts, Ford had clips. Some kits used Granda rotors and GM calipers, this may be what you have ONLY A QUESS, not saying. I will try to find some more info and post up whatever I find. Hope to get this cleared up...Jim
oldman3 is offline   Reply With Quote
Old 09-03-2015, 04:42 PM   #30
yoshi
yoshi's Avatar
Your help is very much appreciated. I assumed this was all Mll stuff, I think the 10 1/2" rotors are ford lug pattern, as you say maybe Granada
yoshi's 49 project
Old 09-06-2015, 09:39 AM   #31
oldman3
oldman3's Avatar
Yoshi, did you every get this taken care of? Just wondering, if more info is needed...Jim
Old 09-06-2015, 01:31 PM   #32
yoshi
yoshi's Avatar
I'm thinking 2 options either turn discs down to 10 1/2" or make some brackets
yoshi's 49 project
Old 09-08-2015, 07:50 AM   #33
yoshi
yoshi's Avatar
Cut a couple of brackets out of 3/8" plate today allowing an extra 1/4" to move the calipers outwards
yoshi's 49 project
Old 09-08-2015, 10:29 AM   #34
oldman3
oldman3's Avatar
yoshi, here's an old pic from back in 89 or so. They welded in a threaded bung on the bracket. If I remember correctly there is a left and right. The bung is offside to the side, so check that closely...Jim
Old 09-08-2015, 10:39 AM   #35
yoshi
yoshi's Avatar
Thanks Jim, on your pic it looks like the threaded bung is welded in after a slot has been cut into the plate. On this pic it looks like it sits on top. It may depend on thickness of the plate. This is 1/4" but I've opted for 3/8" so I'll have to work out measurements. Any idea what thread the other 2 holes are in the plate? I'm thinking either 12mm fine thread or 7/16 unf
yoshi's 49 project
Old 09-10-2015, 03:27 PM   #36
yoshi
yoshi's Avatar
Today I managed to get back on with fitting the 375lb spring. I raised the truck up & placed axle stands in place. Then I put the jack under the lower arm & jacked it up to refit the lower ball joint.
yoshi's 49 project
Old 09-10-2015, 03:30 PM   #37
yoshi
yoshi's Avatar
I discovered I had a problem so I had to loosened the 2 nuts on top to allow the upper arm to come out a little
yoshi's 49 project
Old 09-10-2015, 03:34 PM   #38
yoshi
yoshi's Avatar
I decided not to fit the 2" dropped spindle as I didn't know what springs were fitted & what would happen when I fitted the new spring
yoshi's 49 project
Old 09-10-2015, 03:37 PM   #39
yoshi
yoshi's Avatar
It turns out I should've fitted them. The spring was 3 1/2" taller but must've been a higher lb too as its now 27 1/2" from floor to wheel arch lip
yoshi's 49 project
Old 09-10-2015, 03:39 PM   #40
yoshi
yoshi's Avatar
& 22 1/2" on this side that I haven't done yet
yoshi's 49 project
Old 09-10-2015, 07:28 PM   #41
oldman3
oldman3's Avatar
yoshi, my experence with the stock springs is that they settle down after about 50 miles of driving. So drive it some and then check what the height is. Almost forgot how did you make out with the brake brackets, etc.?..Jim
Old 09-11-2015, 04:48 PM   #42
yoshi
yoshi's Avatar
I ended up turning the discs down to 10 1/2". Here's how it looks at the moment. The disc is just touching the lower control arm but that'll change when I fit the dropped spindles
yoshi's 49 project
Old 09-11-2015, 04:50 PM   #43
yoshi
yoshi's Avatar
Today I fitted the other spring it took me about 2hrs start to finish. This is how it looked before I started
yoshi's 49 project
Old 09-11-2015, 05:59 PM   #44
yoshi
yoshi's Avatar
What's the arm called that runs from the lower arm to the frame? Looks like I need some new rubbers
yoshi's 49 project
Old 09-11-2015, 11:07 PM   #45
Advanced Design
Advanced Design's Avatar
Strut rod and strut rod bushing.
Advanced Design is offline   Reply With Quote
Old 09-12-2015, 03:17 AM   #46
yoshi
yoshi's Avatar
Ah thanks AD
yoshi's 49 project
Old 09-12-2015, 03:54 PM   #47
yoshi
yoshi's Avatar
How the truck looks without the dropped spindles
yoshi's 49 project
Old 09-13-2015, 02:51 PM   #48
yoshi
yoshi's Avatar
Now with the 2" dropped spindles fitted, after fitting the springs & spindles it sits about 2 1/4" higher than it was to start with
yoshi's 49 project
Old 09-13-2015, 02:56 PM   #49
OrrieG
OrrieG's Avatar
It will probably settle a little more too. You have a PM.
OrrieG is offline   Reply With Quote
Old 09-13-2015, 03:05 PM   #50
yoshi
yoshi's Avatar
How much roughly might it drop after settling?
yoshi's 49 project
