Old 09-02-2015, 05:32 PM   #26
rocknss
rocknss's Avatar
Re: What did you do to your Suburban Today?
Now that is what I call low!!
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 09-02-2015, 06:24 PM   #27
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
prepped and painted the buddy bucket center box.
Need to add a stop to the back for the suburban if anyone has done it before
68SWB4x4 is offline   Reply With Quote
Old 09-04-2015, 11:16 PM   #28
3drburb
Cleaned it.
3drburb is offline   Reply With Quote
Old 09-05-2015, 01:18 AM   #29
sierragrande71
sierragrande71's Avatar
Damn that looks good!
sierragrande71 is offline   Reply With Quote
Old 09-05-2015, 01:20 AM   #30
sierragrande71
I did more cleaning on mine
Old 09-05-2015, 01:21 AM   #31
sierragrande71
One more.
Old 09-05-2015, 01:24 AM   #32
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Replaced all the front brake lines and routed them finally! PITA
Old 09-05-2015, 01:25 AM   #33
picklito
Originally Posted by 68SWB4x4 View Post
I
That is one of my absolute favorite color schemes. Especially with the low-line white. GMC, to boot. Wow.
picklito is offline   Reply With Quote
Old 09-05-2015, 12:47 PM   #34
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Thanks man! I always wanted a 50th and when I saw this burb on the side of the hi way I bought it 30 minutes later lol (yes I know its a GMC so not a 50th) same color though...
I really want a 50th truck and my wife does not understand why I would want two trucks that are the same color
Old 09-05-2015, 01:00 PM   #35
picklito
Get some white steelies on that bad boy!
Old 09-05-2015, 02:22 PM   #36
vectorit
What?
vectorit's Avatar
I didn't do anything but drive my burb to breakfast, and stretched her legs out for a hundred miles or so around where I live.
As soon as the heat picks up in my area, it's best for me to get the old girl back home
(No A/C)...
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-05-2015, 04:05 PM   #37
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
I have old slot mags for it with 35s
I'd like some 8" white steelies with original GMC caps though
Old 09-05-2015, 04:06 PM   #38
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
(No A/C)...
I did the same in the Pontiac, such a good feeling.
I'll be down in that area for the Holidays this year I hope to come check your burb out
Old 09-05-2015, 04:06 PM   #39
rocknss
rocknss's Avatar
Installed rear sway bar and fixed glove box door so it will stay closed.
Steven
Old 09-06-2015, 01:42 AM   #40
3drburb
Thanks.
I used what I call Easy Shine in a bottle. Used it for years on all my cars and it works great.
Old 09-07-2015, 05:05 PM   #41
Advanced Design
Advanced Design's Avatar
Ten year old car crazy great nephew came over today. He goes and checks out every old vehicle on the place every visit. So, we took him for a ride in the 72 Burb and the 56 Chevy. He asked tons of questions ( love that) and pretty much went nuts. Had a great time...fanning the flame.
Advanced Design is offline   Reply With Quote
Old 09-07-2015, 06:05 PM   #42
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Which did he call dibs on?
Old 09-07-2015, 06:28 PM   #43
Advanced Design
He thought both were cool and I think he liked the 56 better. He also drove the JD Gator around with his Grandpa and made for a memorable day.
Old 09-07-2015, 06:30 PM   #44
pwdcougar
pwdcougar's Avatar
I went and looked at my finished frame and engine thats in a garage 10 miles away. Been swamped with preparing for my teaching job, small engine repair and a 69 Cougar that runs like crap.
Need to start on stripping and priming the doors. So much for getting the body home before Fall!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 09-07-2015, 09:35 PM   #45
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Installed the rear seat brackets I got off board member 1968K20 I thought about prepping and painting them but decided not to. This suburban isn't perfect and I like it that way.
Now I can sit in the back seat and make vroom vroom noises...
Old 09-07-2015, 10:28 PM   #46
jfalesi
Junior Member
Tried out some aluminum polish on my wheels. First pic, before washing. Second pic, after washing and before polishing. Third pic, after polishing. It's amazing what a little (ok a lot of) polish will do!
jfalesi is offline   Reply With Quote
Old 09-08-2015, 08:14 AM   #47
highwinger
highwinger's Avatar
Nice long weekend gave me a day to knock a couple items off the burb to-do list:
1) tighten ac & ps belts
2) install carb heat insulator
3) oil change
4) reset timing after changing vac advance from manifold to ported
5) tighten valve cover
6) raised fuel line off of valve cover some
7) check front springs & shocks to help determine amount lowered & part numbers if possible
8) tighten clamps & bolts that appeared to be leaking coolant
highwinger is offline   Reply With Quote
Old 09-08-2015, 09:15 AM   #48
LockDoc
The Older Generation
LockDoc's Avatar
3) oil change
Looks like quite a bit to me. That kind of stuff always takes longer than you think it is going to......
LockDoc
Leon
Old 09-08-2015, 09:33 AM   #49
highwinger
highwinger's Avatar
LockDoc
That's the truth...for example, to install the insulator (from Edelbrock) that didn't come with gaskets, I had to search if gaskets are needed (consensus: they are needed), figure out which ones I need and where they are available locally which is becoming increasingly difficult. I didn't realize the primaries & secondaries are different sizes on the Eddie 1406. They aren't as diff as a Q-jet, but not equal like the spacer. After I pulled the carb, I saw the intake is two ovals, not one square, not 4 square...yada. Luckily, Advance had the gasket options and a new 1406 with gasket to compare. So now I have three different shapes between the carb and intake. Hard to say if that reduces performance since I'm not obstructing the paths. It may have been best to have a single square opening like the gaskets...oh well...it got me to work today, so I'm claiming success. I also think it helped hot starts, too, which was the ultimate motivation.
In short...it's the research, decision and part location stuff that takes the most time.
Old 09-08-2015, 11:36 AM   #50
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
What a difference, I'm going to have to try that for my Slots
