Old 08-30-2015, 07:55 AM   #26
Foxcroft80
Re: Stinky Truck
Good input! I'll certainly remove the tape if/when I get a new cap. I have a NAPA close by. Anyone know if those are any good??
Foxcroft80 is offline   Reply With Quote
Old 08-30-2015, 08:36 AM   #27
Foxcroft80
Re: Stinky Truck
Old 08-30-2015, 08:44 AM   #28
Foxcroft80
Re: Stinky Truck
I pinpointed where the leak is coming from. About half way down my driver side door frame (right where VIN plates are) it's fairly wet with gas. I'm trying to upload a picture but so far am not having any luck. Does anyone know what the heck that would be?
Old 08-30-2015, 10:25 AM   #29
Redline novdog
Redline novdog's Avatar
Re: Stinky Truck
Sounds like gas cap/filler neck is leaking
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 08-30-2015, 11:24 AM   #30
Foxcroft80
Re: Stinky Truck
So here's a crazy thought/idea. It appears that the VIN and GM plates were reproductions and I think the guy before me used too long of screws! When I backed off one of the screws and retightened what do you know - a steady leak seeping down the inner door frame and dripping off my running boards. I think one of the screws may have pierced the tank!
Old 08-30-2015, 04:20 PM   #31
Andy4639
Old member
Andy4639's Avatar
Question Re: Stinky Truck
The tank shouldn't be that far over into the cab corner. Your talking the tags on the cab on the back of the door wall that the door locks to when shut. Right?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-30-2015, 04:37 PM   #32
Taibo
Re: Stinky Truck
Just a little advice. If you smoke quit! Then remove the seat to give you room to work, remove the cardboard covering the tank and find out why a screw in the B pillar can cause a leak in the tank which should be 4 or 5 inches away from there! Sounds like the PO hacked something up and if the truck were mine I would find it and fix it right away.
I intend to die in a rocking chair on my back porch, not in a gasoline fire.
Taibo is offline   Reply With Quote
Old 08-30-2015, 05:09 PM   #33
Foxcroft80
Re: Stinky Truck
Haha, luckily I quit smoking awhile back! The guy before me used 2-2.5 inch screws to attach the tags versus pop rivets. I'm almost positive that's the culprit. What do you think?
Old 08-30-2015, 05:12 PM   #34
Foxcroft80
Re: Stinky Truck
I should note that I can feel the screw at least coming close to the tank on driver side door (only place where I've seen evidence of gas).
Old 08-30-2015, 05:21 PM   #35
Foxcroft80
Re: Stinky Truck
Andy4639 - yes. If I could upload a darn pic it would make a lot more sense! Anyhow, I'll be calling the shop tomorrow. I'm all for diving in elbow deep, but not when it comes to leaking gas. Like Taibo said, I'd rather go out a different way!!
Old 08-30-2015, 05:38 PM   #36
cdowns
cdowns's Avatar
Re: Stinky Truck
if it is in fact a leak from a small screw hole it is quiet easy to fix with either marine tek epoxy or something similar like jb weld and it will stop the leak and hold up for many years just cut the screws so they are shorter and don't cum near the tank
Old 08-30-2015, 05:50 PM   #37
Redline novdog
Re: Stinky Truck
I evidently don't know how to quote someone. Cdowns has given a good repair. Yes I went and looked at the '67 if u run a 2.5 inch screw on the passenger side of the tag I think it would hit
Old 08-30-2015, 06:40 PM   #38
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Stinky Truck
Mine is a 71 model and the tank in the cab is long gone but dang I don't remember it going that far over. I could put stuff in the cab corner pockets when it was in the truck. But if that's the case then I would drain it and fix it for sure.
As stated by cdowns not that bad of a job and you may not have to drain it either.
Old 08-30-2015, 06:48 PM   #39
Foxcroft80
Re: Stinky Truck
I'm almost positive that's where the leak is. I ran it down to about 1/4 tank today and while it's still dark around the tag it's not dripping. I'm sure left turns slosh up the gas so it'll probably always be damp until I fix it. I was shocked when I saw that screw there! Oh well, dealing with an old vehicle right? We'll get her! Shame is she's running like a top too. Just take shallow breaths . Thanks all, any other tips aporeciated. If not, hats off to the bow tie!
Old 08-31-2015, 08:49 AM   #40
my67c20
Re: Stinky Truck
After you resolve the fuel leak, you might want to dig deeper into the screwed on VIN plates. Makes you wonder what other wonderful mods the previous owners have done.
my67c20 is offline   Reply With Quote
Old 09-02-2015, 11:20 AM   #41
Foxcroft80
Re: Stinky Truck
it's in the shop now. I'm hoping it's an easy fix. I'll let you know how I make out.
Old 09-03-2015, 07:37 AM   #42
Foxcroft80
Re: Stinky Truck
Hi all, sure enough - 2 holes from screws. 1 punctured and the other nicked. Both holes sadured and seal all applied around whole filler neck for good measure. VIN plates will be reattached with pop rivets this time. Sheesh!!
Old 09-03-2015, 05:01 PM   #43
Redline novdog
Re: Stinky Truck
Good job! nice find, quite unusual ! Now everyone is happy. Hopefully.
Old 09-03-2015, 05:15 PM   #44
leftybass209
leftybass209's Avatar
Re: Stinky Truck
If you ever plan on selling the truck, you may want to consider having your state troopers reattach the vin plate. Buyers tend to get really skeptical when vin plates are being fooled with.
leftybass209 is offline   Reply With Quote
Old 09-03-2015, 07:54 PM   #45
Foxcroft80
Re: Stinky Truck
Lefty - great call. I have them in my glovebox for the time being. I will certainly do that. Not planning on selling any time soon, but always want to be a straight shooter. Happy to have her stink free!!
Old 09-04-2015, 12:10 AM   #46
mike16
Re: Stinky Truck
I got into a pizzin match when I recommended replacing fuel lines to prevent an underhood fire on a previous post. I going to stick my neck out again and recommend replacing other hoses too. use fuel lines and not heater or "other" lines as they might not be compatible with fuel/alcohol.
another possibility is pin hole rust holes in yout gas tank and the sending unit o ring.
mike16 is offline   Reply With Quote
Old 09-04-2015, 07:43 AM   #47
bill3rail
bill3rail's Avatar
Re: Stinky Truck
Glad the problem was found, be aware these trucks are known for gas cap leaks with a full tank and right hand turns.
Mine does this and I removed some of the rubber gas cap gasket and do not fill it up to the top.
bill3rail is offline   Reply With Quote
Old 09-04-2015, 12:26 PM   #48
Foxcroft80
Re: Stinky Truck
Thanks, Bill. I will keep this in mind. My wife insists it still smells, but that's where our opinions differ!
Old 09-04-2015, 06:13 PM   #49
1972_K5
1972_K5's Avatar
Re: Stinky Truck
You might try spraying down the cab corners and seat with an odor eliminator...should help with the leftover odors. It made a huge difference in mine.
1972 K5 CST
1972_K5 is offline   Reply With Quote
Old 09-04-2015, 09:35 PM   #50
LPoole
LPoole's Avatar
Re: Stinky Truck
mine smells of gas sometimes, that's not stinky... my loving wife bought fresh shrimp from a friend of hers returning from the coast. the bag of "fresh" shrimp leaked on my floor... now that was stinky lol. good luck with your gas smell though.
Better to remain silent and be thought a fool than to open your mouth and remove all doubt. - Mark Twain
LPoole is offline   Reply With Quote
