#26 |
Re: to gasket or not to gasket, that is the question
#27 |
After I put on the exhaust manifolds, I figured I would go with Ceramic plug wires that are 45 degree ones. I think they will clear and look the best once I have them all cut to length and dress in.
What do you guys think about the ceramic plug wires? I heard they handle the heat better than the silicone and other ones.
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
#28 |
Moderator
![]() Join Date: May 2007
I've never used gaskets on factory ram horn manifolds. No leaks, no worries.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#29 |
Cruzin
No gaskets for me, had good luck without them.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#30 |
Old member
I put the old 305 TPI in the truck back in late 80's with ram horns. Never used gaskets and never had a leak either.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#31 | |
#32 |
Back to the gaskets. Another trick that works real well is the copper RTV. Skim coat it and it will make a great seal once its been heated once. I gave up on the metal gaskets on turbo motors and only use RTV between the turbo and manifold. Leak free without a single blown out gasket. Clean up is really easy also. A quick pass with a razor blade and the surface is clean. Nothing like when being used on the actual engine.
#33 |
![]() Join Date: Dec 2014
I've used copper rtv instead of gaskets on a set of turbo headers and it worked great
#34 |
gaskets
#35 |
![]() Join Date: Dec 2013
Used Percy's seal-for-good when my stainless exhaust headers warped. Made of soft aluminium. Worked great no leaks - warning you have to tork about three times. Claim to be reusable;e.
