Old 09-03-2015, 09:51 AM   #26
tlmoore2501
Re: lq4 swap wont rev over 2500rpm help please
Have you let it set and run to get up to temp.?Have you put it in gear and drove or attempted to Rev past 2500rpm (power brake)?
tlmoore2501 is offline   Reply With Quote
Old 09-03-2015, 12:48 PM   #27
Liltroy
Liltroy's Avatar
Yes and yes. Several times.
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
Old 09-03-2015, 12:54 PM   #28
Liltroy
Liltroy's Avatar
Ok does anyone know a test procedure for the pedal sensor? Also what should my MAF sensor be putting out? There has to be some way to check this stuff with a multimeter. Checked throttle body operation again last night and it is very smooth. No jerky movements. Tested to half throttle and full throttle several times with engine off and it responded correctly every time but still only 20% with engine running. Reset the ecu and it let me have 27.8% one time after I started the engine, then locked out at 20% again on the next rev. I shut it off, help pedal to the floor showing 99.6% and started the engine and it immediately snapped back to 20%!! Wtf is up with this thing!!!??? I've searched all over the Internet and nobody else has had this issue!!!!!
Old 09-03-2015, 06:40 PM   #29
Liltroy
Liltroy's Avatar
Think my ecu died��
Old 09-03-2015, 07:35 PM   #30
Liltroy
Liltroy's Avatar
So the last few times I used my scanner, every time I started the truck it would blank out the scanner screen. I had to plug it in with the truck already running to take live data readings. Yesterday when I started it I had to toggle the key on and off multiple times before the fuel pump finally kicked on. I chalked it up to oxidation on my fuses or something. Today I went to start it and same issue. I pulled out the multimeter and I'm getting power to fuse, power to relay from fuse and from ignition, but no power signal from ecu to kick the relay. I plugged in my scanner to the one port and it won't connect to the ecu. Can't help but wonder if this has been the problem all along....ecu was on its way out? I can hear the throttle body snap shut when I turn the key forward though.....isn't that controlled by the ecu as well?
Old 09-03-2015, 07:51 PM   #31
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The battery and charging system were verified good, right? At this point I'd figure we checked that....but there are certain systems that will function on 1.5, 5, and 10v...so they can "work" without getting the full 12-14v that they should be getting.
Otherwise, that ecu might be toasted somewhere inside.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-03-2015, 10:17 PM   #32
Liltroy
Liltroy's Avatar
yep I've got over 12 volts at battery. just boxed up the ecu to ship to aknovaman tomorrow to check out. truck is cursed I tell ya!
Old 12-27-2015, 06:20 PM   #33
aknovaman
Its fixed. Harness and file in pcm were jacked up. Liltroy can post burnout pics.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 12-27-2015, 09:07 PM   #34
Liltroy
Liltroy's Avatar
the ultimate problem was I paid good money to the wrong person to do my tune and harness....at least thats the way I see it. Aknovaman got it all starightened out for me though. Thanks Anthony!!!!
Old 12-27-2015, 11:26 PM   #35
72MARIO
72MARIO's Avatar
I read all thru your build last night and noticed you were not happy with the harness when you got it back from the modification post #114
Glad to see you got it running !
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-28-2015, 01:41 PM   #36
slotard
Glad to hear you got it running, too bad it took 3mo longer than it should've.
1973 C20, 350/350
slotard is offline   Reply With Quote
