#26 | |
![]() Join Date: May 2013
Re: New Cam/heads and it wont start. Help!
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#27 |
I put my timing light on while I was breaking in the cam and noticed that as the rpm increases, my timing would retard. But before I could verify this, I burned up my plug wire clamp!
so I need to get a new timing light and find out whats going on. |
#28 |
I started my truck and got a series of small backfires through the carb. When I got it running... Well, It definitely retarded my timing when the rpms climbed. I set my initial timing to 8 degrees with the plugged vacuum advance and the carb port. It went from 8 to zero as I reved the engine. But it had better responce than before I had just adjusted the inital timing. I plugged the vacuum advance back into both ports on the carb and the idle didnt really change. And I felt veryy little vacuum off of each port. By this time I had noticed my headers were glowing red and shut her down. Then I bowed my head in shame and went inside foe the night to write this post.
Any ideas? Junk my distributor and buy a new one? Lol FML |
