Old 09-17-2015, 05:33 PM   #26
68c10owner
68c10owner's Avatar
Re: holley 650 dp on 383
Originally Posted by donpr View Post
Im not concerned about gas mileage, its not a daily driver.
Look up the Quick Fuel Slayer 750cfm vacuum secondary carb. If you don't want the qjet I'd go with this carb. Similar to the 3310 but more adjustable.
Anthony
68c10owner is offline   Reply With Quote
Old 09-17-2015, 06:11 PM   #27
donpr
donpr's Avatar
Is this the one or the 600 ?
http://www.ebay.ca/itm/Quick-Fuel-Sl...cd4076&vxp=mtr
donpr is offline   Reply With Quote
Old 09-17-2015, 08:56 PM   #28
68c10owner
68c10owner's Avatar
That would be the correct one. The 600cfm might work ok as well. Would give better mileage than the double pumper but you mentioned not caring about mileage so thats why I suggested the 750cfm. For this engine stay away from double pumpers all together regardless of the cfm rating. This is a very mild engine that is going to make a lot of low-mid speed torque. A vacuum secondary carb is the best fit for a street/strip set up. If you needed mileage the qjet is best. Drag strip only then the double pumper will work.
Anthony
Old 09-18-2015, 09:45 AM   #29
MikeB
MikeB's Avatar
Originally Posted by Tom View Post
Your not factoring in the massive amount of fuel shot in[doublepump= double shot of gas] every time the accelerator is advanced at all.
I didn't consider that. But doesn't the rear pump squirt only when the linkage progresses to the point where the secondaries start to open?
BTW, back around 2002 I ran a 650 VC Holley modified by QFT on a mild 383 with a Crane cam (210/210; .470"/.470" lift with 1.6 rockers), Dart 180 heads, and Performer RPM intake. It worked well and let the engine rev to 5800 RPM or so, which was 600 RPM higher than with a Performer 2101 and Edelbrock 600 carb. However, I probably didn't rev it that high more than twice! To me the beauty of a 383 is low- and mid-range torque. So you don't have to rev it as much as a 350 to go fast.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-18-2015, 09:58 AM   #30
68c10owner
68c10owner's Avatar
You are correct about the secondaries but they start to open pretty quick because they are set up with the primaries with mechanical linkage where as a vacuum carb relies on engine vacuum or open them.
A 600 cfm carb will starve a 383 if it`s anything more than stock and you are trying to rev it, and 5800rpms isnt high. It all depends on how the engine is built as to what rpm it will need to turn. The same cam in a 350 and a 383 will have 2 different power bands. The bigger engine will be done sooner.
Anthony
