#26 |
Re: Gauging interest in 1972 extreme bend tow hooks
I'm trying to wrap my head around what the liability would even be? That you might break one?
I'm sure a simple disclaimer stating the facts or not intended for use just for looks type thing would suffice. Hey if you're scared go to church! |
#27 |
![]() ![]() Join Date: Jan 2015
Heck mold them out of black plastic they'd be for looks anyway if you do hook to something it's to pull forward like a broke down ford
#28 |
![]() Join Date: Nov 2013
THANKS
to you and all that reproduce parts for us. It is a lot of time, effort and work and I and many here appreciate your efforts. |
#29 |
![]() Join Date: Jun 2002
If fasteners are 5/8" (thanks Jeff) grade 8 then they have a cross-sectional stress area of ~.226 sq in. This gives a tensile strength of ~34,000 and since they would be used in a shear you have to multiply by .6 (actually a bit more, but we should err on the side of caution) for ~21000 lbs times two fasteners for each hook (this is just a swag guys) giving a shear strength of about 41,000 lbs.
I believe in most cases it is safer if the hook bends before a shear situation occurs... JMHO, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd Last edited by raggedjim; 09-25-2015 at 02:13 PM. Reason: Info from Jeff |
#30 |
The bolt size are 5/8" grade 8
#31 |
There are many other factors that go into the stress calculation, such as the moment that will have to countered due to the offset of the pull point relative to the hole pattern. Guesstimating the dimensions, the holes look to be about 2.5 in apart. Conservatively assume 2". Assume 4" pull from center of bolt pattern. 5/8 GR 8 Bolt, .306 in2, 90000psi shear ult., = 27600 lbs. ultimate capacity.
This gives about 8000 lbs pull at the hook to shear the nearest bolt, provided the pull is normal to the plane created by the two fasteners. This will be the failure mode. |
#32 |
![]() Join Date: Jan 2002
Personally I think the original poster deserves a lot of thanks for doing the leg work to get this done. If someone buys a set, its their own risk. I have a blazer with factory tow hooks and the previous owner got stuck. They pulled on the tow hook so hard it actually ripped through the frame, tow hook and bolt were not bent.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
#33 |
Oops - recalc. Wrong center distance.
4" from center: 11000 lbs max hook capacity. 5" from center: 9200 lbs max hook capacity. A forged hook will still be stronger. |
#34 |
Nice work, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
#35 | |
![]() Join Date: Dec 2013
#36 |
please send pic's when you get them Thanks Ted
#37 | |
I never said he shouldn't do it I was merely suggesting he do his homework. It is a litigious society we live in these days. Oh I'm not a wife beater either!
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
#38 |
Tough question. If GM was going for it, they may have specified 4130 or 4340 steel for the forging. That would be pretty cool - but overkill. As someone mentioned before, the frame horns will be the weak point in this system, and that is not the failure point you want. They are likely a fairly common carbon steel.
Here at work, we have a tool that looks like a timing light that you can point at metal, and it will read out the chemical composition. (EXPENSIVE tool). Once I have some hooks I will do this, and the properties will be determined easily. |
#39 | |
#40 |
![]() Join Date: Apr 2008
I would be interested in a set- thanks for offering them
#41 |
![]() Join Date: Apr 2011
UPDATE:
I sent both of my hooks to the foundry that's going to do this for me. We had a conference call this morning. I expressed ALL the concerns of the forum members. As a result, he's going to take a sample of one of mine which sucks a nut because they were so expensive... But in doing so, he can have them analyzed and can copy these hooks verbatim. That's the truth and the fact of the matter. These will be EXACT replicas in every way with the exception of the casting numbers of course. I'm going ahead with this project, there will be 25 sets made. I'm keeping a set for myself and I'm giving a set to my boy. 23 sets will be available for sale. I'll let you all know when I receive them.
JASON 1972 Cheyenne SWB (402/400, tilt) 1972 GMC Sierra LWB (402/400, tach, tilt) |
#42 |
![]() Join Date: Mar 2012
#43 |
Spending on how this goes is this a one and done or is it possible there will be future runs?
#44 |
Moderator
![]() ![]() Join Date: Aug 2011
I work in the turbine industry and we use one of those. The problem arises when the exact metal composition is not loaded into the unit. Then it gives you the closest it can but not exact.
#45 |
I hope this is still a thing because I am interested.
I'm not young enough to know everything. ![]() |
#46 |
I'll jump in line, thanks.
#47 |
![]() Join Date: Jun 2006
I would be interested in a set.
#48 |
Put me in too
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#49 |
![]() Join Date: Jan 2012
I would be in for a set.
#50 |
I'm in for a set. Let me know when they are available
Ugly 61 |
Tags |
extreme bend tow hooks |
