Old 10-28-2015, 12:33 AM   #26
fredscarryall
fredscarryall's Avatar
Re: Project U S Army Sargent Slam
Looks like I am going to need to bring the bed down about 6 inches. Got the bed on and bolted up one of the fenders
fredscarryall is offline   Reply With Quote
Old 10-28-2015, 12:34 AM   #27
fredscarryall
Another pic
Old 10-28-2015, 12:43 AM   #28
fredscarryall
Ordered a set on inner fender wells because the tire are rubbing on the bed.
Old 10-28-2015, 12:51 AM   #29
fredscarryall
Found a 5 window cab that is rust free and had the cab corners and floor done for for a good price including glass. I just need to swap my dash parts and brake booster over
Old 10-31-2015, 12:45 AM   #30
fredscarryall
Took the old cab off the frame today. Installed the trans-dapt S10 motor mounts. But because of the fuel pump bulg sticking out of the block. I had to put the brackets on the frame and oval out the two lower drivers side frame holes. Then put the mounts on the block. Mocked up the blower motor and transmission
Old 10-31-2015, 12:46 AM   #31
fredscarryall
Side view
Old 10-31-2015, 06:09 AM   #32
RockinKees
RockinKees's Avatar
That's a nasty looking engine!
I like it!
Does it all stay under the hood or is it sticking out a bit?
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 10-31-2015, 08:43 AM   #33
Coach529
Coach529's Avatar
Following along..........
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 11-02-2015, 11:45 PM   #34
fredscarryall
Made a cab lift out of 2 x 4s to mount on my engine lift. Got the design off this web site. Worked perfect.
Old 11-02-2015, 11:46 PM   #35
fredscarryall
Another pic
Old 11-02-2015, 11:50 PM   #36
fredscarryall
Cab is on the frame. Now I just have to make some back cab mounts out or 4x4 square tube
Old 11-05-2015, 12:29 AM   #37
fredscarryall
My buddy Chris got the headers,power steering,inner front fenders,fenders on today. Mocked up the radiator surround and radiator. Welded the rear cab mounts and bolted the cab to the frame. We got about a spray can height between the bottom of the fender and the ground with the airbag aired out.
Old 11-05-2015, 12:30 AM   #38
fredscarryall
Pic of front with radiator mocked up
Old 11-05-2015, 12:32 AM   #39
fredscarryall
Got lots of space between the radiator and blower
Old 11-05-2015, 12:36 AM   #40
fredscarryall
Pic of the headers and and firewall clearance
Old 11-05-2015, 12:37 AM   #41
fredscarryall
Looks like I don't have to cut a hole on the hood for the blower
Old 11-05-2015, 11:41 PM   #42
HUSSEY
HUSSEY's Avatar
Great looking build! Those inner fenders on the bed are slick...where are they from?
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 11-06-2015, 12:18 AM   #43
fredscarryall
The bed inner fenders are Dan carpenter specialties.
They measure 28" wide ,11" high and come in 2 3/4 inch,4 inch and 7 inch depths. They cost $310 a pair. Go to dancarpenters.com
Old 11-06-2015, 03:14 AM   #44
fredscarryall
After putting the front fenders and inner front fenders in. it turns out I need the cab to move about 2 inches . I had to order a new 4 inch set back firewall. So until I get that,my work is at a stand still. Kinda sucks
Old 11-06-2015, 03:18 AM   #45
fredscarryall
Scored a trans cover off of ebay for $50
Old 11-06-2015, 11:27 AM   #46
HUSSEY
HUSSEY's Avatar
Those are pricey but man they are nice.
I look forward to seeing how that trans tunnel cover works out for you. It looks like your cab and motor are set about the same as mine. I had seen that cover before but was hesitant to order it, it looked like it might be a bit tight on mine.
Old 11-06-2015, 03:00 PM   #47
ptc
ptc's Avatar
Looking good! nice work! yes those tub look really nice, almost look like spun aluminum...
If you havent bought that firewall yet, you might try ACE hardware and just get a Steel Wheel barrow and cut it up.... I just learned that myself and going that route on my 57 with a BBC.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 11-10-2015, 12:16 AM   #48
fredscarryall
Got the bed inner fenders today and mocked them up
Old 11-10-2015, 12:22 AM   #49
fredscarryall
Don't think I like the painted bumper look to much. I think I'm going chrome instead
Old 11-12-2015, 01:40 AM   #50
fredscarryall
cut out the old firewall with the plasma today. I like the look of the top of the firewall and don't want to redo the hinge spring bolts.so I am only doing a partial.
