Old 04-24-2017, 03:30 PM   #26
mywifestruck
Re: Farm Fresh from ND
so these 2 followed me home this weekend. the yellow one is rough but some very usable parts I have been looking for. The 68 is not an anniversary rig...at least its not identified as on the SPID. It's not an original 4WD, it's on a stretched blazer frame actually.
mywifestruck is offline   Reply With Quote
Old 04-24-2017, 04:26 PM   #27
rusty76
rusty76's Avatar
Cool trucks. I'm following.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-10-2017, 10:04 PM   #28
mywifestruck
Well it's been awhile since I have given an update. So I fab'd in a Blazer Tank.
I used a marine filler neck I bought off of Amazon and brought it to a guy at work to fix the angle a little bit. The Blazer tank filler neck is high, with it mounted as low as possible I still needed to create some room. I bought a gates 90 degree 1 1/2" hose to go from tank to filler neck. I used a holesaw and dremel for the filler neck recess.
Old 10-10-2017, 10:12 PM   #29
mywifestruck
I wanted to keep the old used look so I cleaned up the bed strips that were still good in the truck and I went picking at a local scrap yard for some more. Good strips are hard to come by in the scrap yard. I found 4. I put all new ribbed bolts and bed mounting bolts. The bed wood is white oak, red oak and maple. I got these as rough sawn boards so they needed to be planed, and cut to length and ripped to the width. I used a dato blade for the bed strip grooves.
Old 10-10-2017, 10:20 PM   #30
mywifestruck
I cut the old U bolts out and put in new CPP shock mounts and 2" lowering blocks. I flipped the trailing arm mounts in the front. After I did that these trailing arms showed up on CL. I talked with the seller and took a little road trip to WI to get them. They had been coated with tar at some point shortly after new and there's not a lick of rust on these things. So it all needs to come apart again. I don't have the springs and shocks yet so I will just do it when I get them. Once I am done with the rear end I will start on rebuilding the front end.
Old 10-10-2017, 10:21 PM   #31
mywifestruck
found this seat when I was out picking parts. It's probably something I need.
Old 10-10-2017, 10:27 PM   #32
mywifestruck
I took in a couple of car shows over the last month and saw these. The Cheyenne was beautiful. The Blue long stepper was an old navy firefighting truck they used on an Air Craft Carrier and was used to carry airpacks. That thing was a pretty nice original truck.
Old 10-11-2017, 12:08 PM   #33
rusty76
rusty76's Avatar
Thanks for the updates
My build thread
Crossmembers CC
Old 10-11-2017, 12:20 PM   #34
68Gold/white
Carry on!!!
Look'n good!!!
Glad you are back making progress.
Looks like you have a good crop of 67-72's going there.
68Gold/white is offline   Reply With Quote
Old 10-31-2017, 03:47 PM   #35
mywifestruck
Got the wheels painted last week. They turned out alright. I think I am going to go with Mastercraft A/S IV tires.
Old 11-08-2017, 11:26 AM   #36
too much stuff
Roadtrip!
too much stuff's Avatar
Yep, I remember when you got this. Looks good. I will check out my tailgates later today...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
