10-10-2015, 10:01 PM | #26 |
Re: Stainless steel rocker panels
I like this stuff - believe it is a mixture of a paraffin or wax based substance and a solvent - so it flows into any crevices and blocks off the oxygen to help stop the rust from continuing or getting worse anyway
Available at Home Depot so that helps... And it has a straw on the aerosol so you can spray it into tight spaces Probably need to renew it once a year or so I'm with the guys above who mention galvanic corrosion as being the major issue - after all we know that with a more noble metal like stainless fastened to a less noble metal like carbon steel - the problem is at the interface (weld or rivet).. But Also as we know from plumbing pipes - if you make the connection gradual, for example by going from stainless to brass and THEN to carbon steel; the galvanic potential is less at each transition and will be less of a problem - though whether or not this is sufficient is beyond my skills to say. Good idea though; and it is nice to see people willing to contribute ideas to start the discussion. I also like the ideas above of concentrating on eliminating any blind cavities in areas of steel panels exposed to salt spray.. that might alone just be enough with proper maintenance to turn a five year problem into a fifteen year problem.. |
10-12-2015, 08:23 PM | #27 |
How about a repop rocker panel that is made from the correct heavy gauge steel and not the thin crap? Or better yet, made from a heavier than OEM gauge steel. I think that is much more feasible than a stainless rocker panel, and would stand the test of time if installed and treated properly.
07-27-2016, 07:37 PM | #28 | |
My Experience comes from working in a Auto Body Collision Center. |
07-27-2016, 07:50 PM | #29 |
I don't know where you read that Chevrolet & GMC is going to get the Aluminum treatment also. Chevrolet made that Commercial that KICKED Fords A** when they dropped bricks into both trucks beds and you did see what happened to the Ford bed didn't you well IT SWISS CHEESED the Fords bed. SO why would Chevrolet do it to there own product when they CREAMED Ford SO WELL.
07-27-2016, 07:52 PM | #30 |
07-28-2016, 08:43 AM | #31 | |
http://www.autoblog.com/2015/08/05/g...ucks-aluminum/ http://www.autonews.com/article/2014...18-report-says |
07-28-2016, 07:42 PM | #32 | |
07-29-2016, 05:51 AM | #33 |
Chevy was looking at this year's 1500 truck sales. When they come out with their aluminum truck they would like you to forget that ad that proved people are stupid if they dump cinder blocks into any truck bed made from any metal without first providing some protection...such as a $15 sheet of plywood (with 2' cut off so it will fit a cute little short bed)
This issue here with rockers, cab corners, and supports is drainage. These are at the bottom and they hold accumulated road grime and dust. It holds moisture against the metal. Add salt to that crud and it really attacks the metal. With better drain holes it is also easier to get a good flush of water up in there and better to drain out. I think holes with plugs in the back side so you can squirt rust prevention of your choice in would be a good not visible thing to do, along with opening up bigger drain holes on the seam
07-29-2016, 05:22 PM | #34 |
Who's driving these trucks in road salt? That's the only time I see it relevant. Otherwise install stock steel and prep it well and take care of the truck..... SS is overkill in this application...
07-29-2016, 06:41 PM | #35 |
Every time my dad did an oil change he used the old oil to spray into the wheel wells, and sometimes he'd paint it on to the undercarriage.
Cab corners still rusted out! But everything else lasted 30 years...
07-29-2016, 06:50 PM | #36 | |
07-30-2016, 02:14 AM | #37 |
Yah I think you are right. Chevy is blowing it by having more Aluminum in there trucks, but hay Aluminum is lighter right. If thats so why are they getting so piss pour gas mileage still. The only thing that is doing better is a Diesel not that much better but better. just my .02 cents
07-30-2016, 10:53 AM | #38 |
I like to pre-plan things like a rocker install. By pre-plan I mean figure out where you need to weld. On a rocker you got the bottom lip, a few spots along the top, and a few spots on each end. Put tape in those spots. Then spray epoxy primer on the inside. Remove the tape. Spray bomb weld through primer where the tape was. Cut off old rocker. Weld on new rocker for the last time.
I filleted open an original box side and did this treatment. 100 years from now there is going to be a truck in a yard somewhere with one good box side and a pile of rust dust around it.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
07-31-2016, 02:29 PM | #39 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
