10-20-2015, 11:39 AM | #26 |
Post Whore
Re: 2" Shorter Coil Springs = 4" Drop ?!
Than you Ben I appreciate that. Sent another email to Tom letting him know I keep buttoming out when I drive over mild speed bumps on my street. Seriously leaning towards returning these springs.
10-20-2015, 12:24 PM | #27 |
Don't know if this helps but I think the front will come up some as the rear is lowered. If it will be enough I don't know.
10-20-2015, 12:34 PM | #28 |
Perhaps its a lower control arm issue and not a spring issue? I mean you could get @Houston Ben to measure his springs and you could compare spring height.
But it could also be a spring softness issue too? I know springs are usually measured by figuring out how much weight it takes to compress it one inch. |
10-20-2015, 12:43 PM | #29 | |
Born and proudly residing in a Red State ! |
11-07-2015, 12:32 AM | #30 |
Post Whore
well Gentlemen the saga continues, I waited till November so I could have money to buy new coil springs, I thought hey lets buy them from LMC Truck so that they take the guessing game out of the equation for us, right, I mean those guys should know these trucks
so today the package arrived, I got the coil springs and the leaf spring hangers for the rear want to first show you the way LMC Truck packages their stuff because I believe they fired their efficiency experts back in '86 LOL |
11-07-2015, 12:36 AM | #31 |
Post Whore
now you all may wanna be sitting down for this next part cause it's about to get real
LMC Truck sent me the exactly precisely unequivicably same McGauphys coil springs that I already had, that I already bought from McGauphys that dropped my truck way too much Did I call LMC Truck before ordering? YES Did I ask them if they could tell me what brand these coil springs are? YES They said they could not tell me that info because they did not know / have it. LMC Truck has no Technical Support department and their call center is lame. |
11-07-2015, 01:31 AM | #32 |
Post Whore
do you recall the part number bro?
I am eyeballin' these: 1974 GMC C15 C1500 PICKUP Summit Racing® Dropped Coil Springs SUM-G727 |
11-07-2015, 01:49 AM | #33 |
At the body shop.
Why don't you get a stock set, and clip a coil?
" That didnt make it any newer " " Dont antique the equipment " |
11-07-2015, 03:00 AM | #34 |
Post Whore
Seriously considering doing just that. I didn't want to at first because of all the stuff I read and heard about getting the right spring size and tension with the proper bottom to make enough contact with the bowl, I guess when you cut a spring there is less contact between the bottom loop and the bowl cup it sits in, that type of thing
11-07-2015, 04:34 AM | #35 |
You CANNOT tell "Spring Rate" by looking at a coil spring, They could still be different.
Desert |
11-07-2015, 11:07 AM | #36 |
I know the pieces fit
I don't and Summit doesn't show my order history that far back. But I looked in their catalog and the ad hasn't changed in all these years, those are the pair I ordered.
11-07-2015, 12:28 PM | #37 |
Post Whore
They have the exact part number written on each spring, that's what I am going by. Not willing to install these just to check them, since I might scratch them up and then they won't want to take them back. And what would it say about their product if two sets of exact same part number springs sagged and recoiled differently? Just something to think about, I guess.
11-07-2015, 01:44 PM | #38 |
The initial dropped picture you posted looks dandy. It is about where most fronts site when combined with a flip kit out back.
Aftermarket springs give you what they expect for drop, but since no vehicle is perfect, the amount of drop may vary. Maybe your truck had different springs. Maybe your truck weighs less. Maybe maybe maybe. Fact is - it sits where it sits. Riding this low, using springs but not spindles, does a couple things: It may increase bumpsteer because the control arms and tie rod ends won't be "optimal" (if there is such a thing in these trucks) - but you will drive around it subconsciously. You likely won't even notice. It may increase front tire wear due to more "scrub" (that is, as the control arms start deviating from horizontal, the tire starts scrubbing sideways over a bump, wearing the tires out). It might be noticeable, but only time will tell. You may not have much bump travel. You could, if you had to, trim the front bumpstop (or cut down the bumpstop tower and install an Energy Suspension bumpstop of some kind/height) so that you hit the stop before the wheel hits the underside of the fender. Keep the McGaughy's you bought previously, return the LMC ones, flip the axle, and ride on! It will be fine. Truck guys have been doing it this way for years. It works fine.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
11-13-2015, 11:40 AM | #39 |
Post Whore
quick update, decided to just cut a loop off of my stock coils and that gave me a perfect 2" drop, thanks for the suggestions everyone
also, shipped the McGauphys coils back, the US Post Office wanted $50 bucks to ship the original package back which weighed over 30 pounds but luckily they fit in their large Flat Rate box, which allowed them to be shipped for only $18 bucks lets keep our fingers crossed to see if the Greg will get his refund here is a pic of 2" drop in front by cutting stock springs, and a 2" drop in rear using 2" taller aftermarket shackles, (we are also going to add 2" taller leaf spring hangers in the back to level this green machine - wish me luck) |
11-24-2015, 08:11 PM | #40 |
Post Whore
figure I would give you an update on this McGaughys coil spring fiasco. so after having returned the springs to them and not having heard back, I emailed them, and Tom emailed me back and said my package was refused because it did not have the ORDER # on it, and their folks are trained not to accept those types of packages
11-25-2015, 12:08 AM | #41 |
So if they refused it where did it go? Is the post office returning to sender?
11-25-2015, 02:27 PM | #42 |
What a fiasco, I also wonder where are they then?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
11-25-2015, 05:43 PM | #43 |
Post Whore
Exactly, I emailed Tom and asked if he could provide a link to where it says that on their website, he sent me a link but here's all it says, there is nothing here about including your Order # on the outside of the box:
http://www.mcgaughys-suspension.com/shipping-returns/ Shipping & Returns Returns Policy You may return new, unopened items within 15 days of delivery for a refund minus a 20% restock fee and original shipping charges (if shipped for free) . We'll also pay the return shipping costs if the return is a result of our error (you received an incorrect or defective item, etc.). Absolutely No Returns After 15 Days. You should expect to receive your refund within four weeks of giving your package to the return shipper, however, in many cases you will receive a refund more quickly. This time period includes the transit time for us to receive your return from the shipper (5 to 10 business days), the time it takes us to process your return once we receive it (3 to 5 business days), and the time it takes your bank to process our refund request (5 to 10 business days). If you need to return an item, simply login to your account, view the order using the "Complete Orders" link under the My Account menu and click the Return Item(s) button. We'll notify you via e-mail of your refund once we've received and processed the returned item. ------------------------- can someone explain to me why in the world someone would return an unopened item, oh look here is a brand new part I ordered and have been waiting on for days, I know I will turn around and return it for a full refund, well duh no, you will open it and look at it and only if it is red and you specifically wanted a darn blue one will you know that it is the wrong part, and only then know to return it, geez |
11-25-2015, 07:32 PM | #44 |
I hate this bull****. I once returned something to rock auto and forgot a piece of paper. it was rejected and sent back.
by the time I could send it back grace period was up and they wouldn't refund me. |
11-25-2015, 07:48 PM | #45 |
One of the reasons I try to do all the business I can with Summit or Jegs, no hassle, ever
11-25-2015, 08:09 PM | #46 |
