Old 09-15-2016, 10:44 PM   #26
NW Task Force
NW Task Force's Avatar
Re: CPP Brake Conversion
Yes, I agree! I am looking at buying a new master cylinder with 1-1/8" piston and the matching disc/disc proportion valve. This one to be exact:
http://www.ebay.com/itm/Disc-Disc-Ma...9S-6~u&vxp=mtr
What is the difference in advertising for 2-port vs 4-port? I assume 4 port has 2 outlets on each side of the master cylinder body?
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original
NW Task Force is offline   Reply With Quote
Old 09-15-2016, 11:58 PM   #27
dwcsr
Hollister Road Co.
dwcsr's Avatar
yes, 4 port has outlets on both sides of the master, It will also have a slug that goes into the master cylinder piston rod bore to convert it from a manual master to a power brake booster and you may have to readjust your booster pin.
dwcsr is offline   Reply With Quote
Old 09-16-2016, 10:42 PM   #28
NW Task Force
I am interested in the standard OEM 2 port design. What is the purpose/application for a 4 port unit?
Old 09-16-2016, 11:11 PM   #29
dwcsr
Hollister Road Co.
dwcsr's Avatar
Its purpose was so vendors didn't have to carry both left and right port master cylinders. Its purely an aftermarket master designed to cut down inventory. It comes with plugs in one side to block off what you don't use
Old 09-17-2016, 02:54 PM   #30
NW Task Force
I see. Thanks for clarifying........ I was confused on what the purpose/difference was.
Old 09-19-2016, 10:54 AM   #31
yossarian19
FWIW, a 1 1/8" master cylinder is more than enough cylinder diameter for running big twin-piston front calipers + rear disc. I know this from having put a 1 1/8" master on a Jeep I had with the brakes I mention... pedal felt great but I did lose some brake performance, I think, vs the 1" master that was in there. Set up from the factory, my daily driver (with the same brakes as the old hot-rod jeep) uses a 1" bore.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
