Old 12-30-2015, 09:00 PM   #26
bealaddison
bealaddison's Avatar
Re: Seat Upgrades??
I didn't get any pictures, but I was able to mount the '99-06 center console between my existing buckets. It already had a seatbelt made into the mounting points. I just needed to trim the mounting pad and remove the inner arm rests on both the front buckets. It fits very well, doesn't interfere with the transmission or transfer case shifter, and I have the option I was looking for. Seat height is perfect and with some new upholstery it will blend in perfect. I used 1/2" bolts and oversized washers to mount it. It sat perfectly on the floor pan after I cut the width of the foot and redrilled the mounting hole. I would recommend this to anyone looking for something similar.
'87 Chevy V20 Suburban
6in Lift, 37in Toyos/Nittos on 17x9 KMC Diesels
2009 Chevy Silverado 2500HD
6in Lift, 35in Toyos on 20x9 KMC Monsters
bealaddison is offline   Reply With Quote
Old 01-23-2016, 02:07 AM   #27
'68 Newtricks
'68 Newtricks's Avatar
Re: Seat Upgrades??
Depends on what you use your truck for. My blazer came with mid 90s tahoe seats, poorly mounted. While comfy, they had no bolstering. I adapted some early 2000 Suburu WRX seats in. Driver seat uses all original floor mounts while the passenger uses the front holes and new supports for the rear. I even saved the track sliders for the passenger seat, to use for rear seat entry.
Why? Cause my truck is 95% offroad minded. I need the bolstering, plus tilt back and ease of getting in and out. Something to think about.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 02-03-2016, 07:44 PM   #28
Rmy660r
Re: Seat Upgrades??
I just went through the same issues for my 91 Suburban. I bought 99-06 Silverado seats and they were too tall. I ended up getting Chevy Cruze seats and they worked great. I used the console from the Silverado seats. I had to make a bracket for each seat for the inner front corners.
Rmy660r is offline   Reply With Quote
Old 02-04-2016, 12:46 PM   #29
Front Range
Front Range's Avatar
Re: Seat Upgrades??
Those look comfortable.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
