Old 09-04-2016, 11:44 AM   #26
drewbert41
drewbert41's Avatar
Re: Need help with my steering column
When I push on the cup with my fingers it makes a clicking noise like it should but when I put the cap on it will not stay and does not make contact with anything.
drewbert41 is offline   Reply With Quote
Old 09-04-2016, 09:45 PM   #27
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by drewbert41 View Post
I have looked all over the web for the horn button cup and all things I can find say they are the same for 60-72
http://67-72chevytrucks.com/vboard/s...d.php?t=437708
http://67-72chevytrucks.com/vboard/s...d.php?t=614258
LockDoc
Leon
Old 09-06-2016, 10:34 AM   #28
drewbert41
drewbert41's Avatar
Thanks again Leon. A lot of misinformation out there on this subject.
Old 09-06-2016, 01:02 PM   #29
LockDoc
LockDoc's Avatar
No problem. I ran into the same thing a few years ago so I knew there was a difference.
LockDoc
Leon
Old 09-06-2016, 01:03 PM   #30
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Originally Posted by Dagr8npwrfloz View Post
As I understand it the little red hazard button was 68 only.
From what I understand the red hazard button is for non-tilt steering wheels, not 68 only.
That said, mine has the black button instead, which is supposed to be for tilt. I was told it's wrong. Can anyone confirm?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-06-2016, 01:41 PM   #31
FlounderGDI
FlounderGDI's Avatar
One thing I always forget about when I reinstall my steering wheel and horn button... I have to clock the cup so the cutout lines up to the key on the horn button... My horn button won't stay on if my cup has the notch in any position other than the 12 o'clock position (with the steering wheel straight)
In your picture your wheel is right but the horn cup looks like it needs to turn 120 degrees to put the cup notch at the top then you'd press on the horn button with the notch at the top too.
1969 CST/10 "GreenAndWhite"
1974 Nova (SOLD... End of an Era)
2000 Impala (RIP)
2008 Malibu
Brand Loyal... I've never owned a Vehicle not made by Chevrolet.
FlounderGDI is offline   Reply With Quote
Old 09-06-2016, 02:42 PM   #32
webfoot
FWIW - that "pressure plate" you speak of is for the locking columns with the in-column ignition switch, which GM began using in cars starting in 1969, and in trucks starting in 1973.
This paper shows exploded diagrams of a 68 GTO steering column but the parts are similar if not the same other than the steering wheel.
http://thefirstgensite.com/library/6.../steering.html
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 09-06-2016, 07:19 PM   #33
71CHEVYSHORTBED402
Question, dumb perhaps...........Is the button in the canceling cam for the horn?
Tony
Old 09-07-2016, 10:09 AM   #34
drewbert41
drewbert41's Avatar
Thanks, I will make sure to do that when I get the right sized cup. No contact is made at all right now because mine is too short.
Old 09-07-2016, 10:11 AM   #35
drewbert41
drewbert41's Avatar
Red Hazard button is part of the turn signal switch I bought from GMC Paul.
Old 09-07-2016, 10:12 AM   #36
drewbert41
drewbert41's Avatar
Really glad I dont have to deal with one of those!
Old 09-07-2016, 02:50 PM   #37
71CHEVYSHORTBED402
These posts are real helpful. I pulled the cap off my 72 to check positioning of the spring loaded pin/button on the canceling cam was located. Like my 71 it's at 10 o-clock. So I put it back together and no horn. It's a new truck to me, and I dumb neglected to see if it worked in the first place. Don't know if cleaning the top of the rim in the steering wheel was it, but now it's working.
Like Doc mentioned, that disk isn't flat. The "dome" side faces rear of the truck. The slot in the retainer faces up to attach the button. If you have the right cup and it's still not working, try backing off the screws a hair, might help.
That canceling cam do two different things? One cancel the turn signal and two make contact for horn operation? Guess I'm wondering what the spring loaded pin that contacts the metal disk is used for.
Tony
Old 09-07-2016, 03:46 PM   #38
webfoot
The cancelling cam also has the horn contact in it, the ground is complete when the horn button is depressed. The turn signal switch has a button in it as well for horn grounding.
-me
Old 09-07-2016, 05:19 PM   #39
71CHEVYSHORTBED402
Just what I was looking for. Thanks a bunch Web.
Tony
