11-25-2015, 07:18 PM | #26 |
Moderator
Re: Hot Start Solution fo my Truck
A thermal wrap around the solenoid/starter eliminated my hot start issues with an OEM starter. I've never had that problem with a mini starter.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
11-25-2015, 07:21 PM | #27 | |
Your grandpa's purple solenoid wire in his '63 Biscayne Four Door always worked because no one monkeyed with it, cut it, or otherwise compromised it. Otherwise GM would have had a rash of warranty work every time it got hot in the South. I'm talking about stock setups; I'm sure it's possible to cook a starter enough with headers that some insulation is required. I don't think the starter-to-block ground is a common problem, as once you managed to get the solenoid to fire you'd still have a marginal starter ground so it'd crank slowly best case.
11-25-2015, 07:48 PM | #28 | |
I just tore down a reman two weeks ago, they haven't changed yet. |
11-25-2015, 09:04 PM | #29 |
Old member
Lets put this in easy to understand terms.
All the solenoid does is move the small purple GM starter wire to the new solenoid and uses a bigger heavy duty cable to feed the GM starter and jumper the small "S" terminal on the GM starter to engage it. You are not bypassing anything. This is how all newer vehicles are wired now form the factory except they use relays instead of the solenoids. I bet you could use a 50 amp relay like for a fan motor and do the same thing. When you think about it it's just like the relay kits for your head lights. Your taking the load off the main electrical system and using relays are in this case a solenoid. Both are serving the same purpose as a electrical ON/OFF switch for the circuit. http://www.superchevy.com/how-to/148...-no-start-fix/
11-25-2015, 09:26 PM | #30 |
Well I certainly appreciate all of the knowledge. I guess I never put that much thought into it. I fixed my heat soak problem with a remote soliniod ages ago and moved on to the next project.
11-25-2015, 09:33 PM | #31 |
Moderator
X2. I fixed the problem and moved on. There are many ways to solve an issue, as long as the end results are the same it's a success.
11-25-2015, 09:57 PM | #32 | |
