Old 11-28-2015, 07:41 AM   #26
jason999
Re: Looking for advice on how to add or fix my fan problem.
I'm in the same boat with a similar setup. My 66 also has a 350 where the 327 used to sit. The new fan moved in with the motor. I have a short water pump and I do NOT have a spacer, like the OP, on the fan.
Is a factory shroud likely to fit with my (and the OP's) more modern fan?
Also, I saw a post sometime back that showed a nice looking shroud that was made from a universal kit from Summit or Jegs. I don't remember the details. Can anyone recommend a kit that they've used?
jason999 is offline   Reply With Quote
Old 11-29-2015, 01:16 AM   #27
Captainfab
60-66 Nut
The stock style shroud will work with a small block with a short water pump and a clutch fan as long as the diameter of the fan is not too large. There are different diameters of fan blades. I do not have a fan shroud here at home to measure to give you a dimension.
Old 11-29-2015, 01:45 AM   #28
padresag
the one that I have is 19 11/16". it came out of a 66 with a 327
ron
padresag is offline   Reply With Quote
Old 11-29-2015, 01:47 AM   #29
Captainfab
60-66 Nut
Is that the shroud opening or the fan diameter?
ron
Old 11-29-2015, 02:33 AM   #30
padresag
id of the opening in the shroud where the fan goes
ron
Old 04-07-2016, 10:53 PM   #31
Monte's62
Originally Posted by 42_NATO View Post
Well my 65 has a 350 in it and starts over heating after driving a while only when im at a stop or moving slowly . ive made the conclusion that since i dont have an engine shroud. The water pump fan isnt pulling enough air from the radiator. So i was looking into buying the shroud but new there running 130.00 . i also looked into just adding a fan or two.
I have a fan from a previous car that should work . so should i just add that fan on a toggle switch .
Or should i buy the temp sensor and relays for the fan and remove the old water pump fan.
Or should i just buy the shroud.
42 NATO, did you get a shroud to fix this issue?
Monte's62 is offline   Reply With Quote
Old 04-07-2016, 11:06 PM   #32
gmachinz
How much room do you have between the pump snout and radiator?
gmachinz is offline   Reply With Quote
