Old 12-29-2015, 07:42 PM   #26
yelmer
Re: build of a 1966 c-20 custom camper
as it goes parts off to blasters and painters waiting for them to return
yelmer is offline   Reply With Quote
Old 12-29-2015, 09:59 PM   #27
aotte1
Looking good, lots of great progress. Really good feeling when it's all apart and off to be recondioned, knowing you get to start putting it back together soon.
Find any neat stuff on the frame, clips ...etc. finishes, markings, and brake line fittings.
Going to replace the brake lines, and keep them original looking? Any specific company that does good original lines.
Les
aotte1 is offline   Reply With Quote
Old 12-29-2015, 10:22 PM   #28
yelmer
on the rearend third member had a white paint mark on it . also orange paint marks on the front springs also had a alum tag on the steering control on the right side has numbers on it . when i get it cleaned i will post
Old 12-29-2015, 11:34 PM   #29
aotte1
Really like this original factory stuff/knowledge too.
Look forward to see information/ photos on your special truck.
L
Old 12-29-2015, 11:44 PM   #30
sodly
sodly's Avatar
Always fun to watch your work, Yelmer! Can't wait to see the pieces painted. Did that truck have a 4.57 or 4.10 rear end?
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 12-30-2015, 10:27 AM   #31
yelmer
4.57 hope to install locker unit if looks good
Old 01-25-2016, 10:46 PM   #32
yelmer
frame back for power coating tranny pictures and rear cab mount with new rubber
Old 01-25-2016, 11:06 PM   #33
cru_zn_29
cru_zn_29's Avatar
Looking good
cru_zn_29 is offline   Reply With Quote
Old 01-26-2016, 11:34 AM   #34
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Nice!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-26-2016, 11:56 AM   #35
60-66
60-66's Avatar
Looks great Mike ! Question , what plan do you have for re mounting the rear cab mount to frame ? I've been talking to a couple guys about riveting brackets like these back in place on these trucks. Apparently the rivets are available, although I haven't looked for them yet.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 01-26-2016, 01:51 PM   #36
cru_zn_29
cru_zn_29's Avatar
I got mine from McMASTER-CARR
Old 01-26-2016, 07:33 PM   #37
yelmer
i thought about rivets . what did you use to install them with
Old 01-26-2016, 10:27 PM   #38
cru_zn_29
cru_zn_29's Avatar
I used a big old sledge hammer and drilled the size of the rivet about 5/8" head in the head of the hammer. Don't drill in the center drill it needs to be offset then i drilled the end of 1"X 8" long round stock I used 5/8" bit fit my rivets. I had a friend hold the sledge hammer on the mount side I used the 1" driver and sledge on the inside of the frame
Old 01-26-2016, 10:31 PM   #39
yelmer
thanks for the tip .
Old 01-27-2016, 01:13 AM   #40
aotte1
The frame looks very nice, what level gloss did you use for power coating on frame? I like some gloss as it cleans a lot easier.
Great detail on the transmission.
Les
Old 02-29-2016, 10:44 PM   #41
yelmer
frame is power coated with appx 70% -30% gloss . More progress working on motor very close . Wheels at paint , tires on there way
Old 03-01-2016, 01:45 AM   #42
aotte1
Looks great, coming along really very nice!!
How are you doing your bolts, using originals and recoating them with cad, black zinc, etc?
On '64 will likely use original bolts with ceramic coating, not original but seams to stand up well and is a hard coating, not damaged by installation. Not original purpose of ceramic coating, however, works. Needs to be done under controlled conditions.
Some more close-up photos would be nice too. Frame clips for brake lines, wire harness, emergency brake cable, etc. Would like to see if they changed during the years or stayed the same.
Les
Old 03-01-2016, 02:41 AM   #43
Bomp
Bomp's Avatar
Nice and clean.
Bomp is offline   Reply With Quote
Old 03-01-2016, 09:41 AM   #44
yelmer
using original bolts replated
Old 03-01-2016, 10:53 AM   #45
cru_zn_29
cru_zn_29's Avatar
Looking good
Old 05-30-2016, 10:14 PM   #46
yelmer
updates still progress
Old 05-30-2016, 10:22 PM   #47
yelmer
more
Old 05-30-2016, 10:47 PM   #48
aotte1
Mike,
The engine and drive train looks outstanding, thanks for sharing. The green/blue for the 327 is much cooler then 283 Navy gray!
Did you clear coat your drive shafts?
FYI, On '64 K10: drive shaft u-joints caps have the same orange inspection markings too, along with yellow on the yoke and shaft up to slip connection.
Les
Old 05-30-2016, 11:20 PM   #49
yelmer
i put a light coat of oil i have the same on the red truck it works well
Old 05-30-2016, 11:43 PM   #50
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Engine and frame are outstanding! Great work. Truck is gonna look sweet!
