Old 03-08-2016, 02:06 PM   #26
slimneverdies
slimneverdies's Avatar
Re: Fuel sending unit question
Originally Posted by CSHADES View Post
When I rewire any vehicle I always treat the grounds like the car is made of fiberglass and run dedicated grounds from each device to a ground bar that I install either under hood or in the cab. Otherwise you are going to have to grind some of the powdercoat off, which takes away the advantage of powdercoat.
Can you ground off stainless steel. I can put little stainless tab/bars to bare metal in a few places so I can ground.
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 03-08-2016, 06:38 PM   #27
CSHADES
CSHADES's Avatar
Yes you can do that as long as everything is clean and shiny. Use some grease over the top of the connections when you are done. At least you don't have salt to worry about.
CSHADES is offline   Reply With Quote
Old 03-08-2016, 08:14 PM   #28
slimneverdies
Cool. I get the idea now. Thanks
Long live SLIM
