Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 12-20-2015, 09:16 PM   #26
Mikes66ChevyC10
Mikes66ChevyC10's Avatar
Re: Cab Pieces/Parts
Originally Posted by DPowers View Post
So a section like this is what you need?
Yep looks good to me.
1966 C10 Stepside swb
http://67-72chevytrucks.com/vboard/s...d.php?t=617778
Mikes66ChevyC10 is offline   Reply With Quote
Old 12-20-2015, 09:18 PM   #27
DPowers
DPowers's Avatar
Originally Posted by niterider65 View Post
if your going to cut up the cab i need the right side cab corner if its not bondo all up
and if it could be over cut so i can drill out the spot welds on the rocker side and cut out just past the first circle in the back of the cab if its not taken
just let me know how much shipped to 76107
Is this the section that you need?
DPowers is offline   Reply With Quote
Old 12-20-2015, 09:22 PM   #28
DPowers
DPowers's Avatar
Originally Posted by 62jimmy View Post
If any good I would be interested in the front half of the passenger outer rocker panel it you decide to dice it up, thanks, jeremy
Can you get me a pic of the exact area you are talking about and i can check.
Old 12-20-2015, 09:24 PM   #29
DPowers
DPowers's Avatar
Ok I will cut it out. How would $15 plus whatever shipping would be?
Old 12-20-2015, 09:30 PM   #30
Mikes66ChevyC10
Sounds good to me. Thanks again for doing this. This spot is the last area of rust on the cab that needs to be fixed then all the rust repair is done!
Old 12-20-2015, 09:32 PM   #31
DPowers
DPowers's Avatar
no problem. will keep you posted
Old 12-20-2015, 10:19 PM   #32
niterider65
niterider65's Avatar
That will work
niterider65 is offline   Reply With Quote
Old 12-20-2015, 10:27 PM   #33
niterider65
Cool Re: Cab Pieces/Parts
Old 12-20-2015, 11:31 PM   #34
DPowers
DPowers's Avatar
How's $20.00 plus whatever shipping is?
Old 12-21-2015, 01:19 AM   #35
62jimmy
This part of the rocker is what im looking at. As you can see mine is smashed flat up against the cab, I was hoping for a piece about mid door forward that included the plug hole in the front.
62jimmy is offline   Reply With Quote
Old 12-21-2015, 02:44 AM   #36
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by LostMy65 View Post
I need two of these cab mounting washers:
I only need the washer with the cupping. The washer in the square cut area there. I need two of them.
66 C20 Service Truck:
Old 12-21-2015, 08:18 PM   #37
DPowers
DPowers's Avatar
this work?
Old 12-21-2015, 11:45 PM   #38
aotte1
Need two firewall pieces on both sides of the tunnel area, where BB valve covers would have dented firewall, can post photos of area needed. Is this available
L
aotte1 is offline   Reply With Quote
Old 12-21-2015, 11:53 PM   #39
aotte1
One of two firewall pieces needed, left side, would like a little larger piece, as will weld in.
L
Old 12-21-2015, 11:55 PM   #40
aotte1
Other firewall piece needed, right side, would like a little larger piece too. Photos of patches would be nice.
L
Old 12-22-2015, 12:18 AM   #41
DPowers
DPowers's Avatar
Like this whole section?
Old 12-22-2015, 12:58 AM   #42
62jimmy
this work?
Plug end looks good to me. I would need it cut back about 14 or 15 inches into the rocker to straighten it out?
I forgot to ask is the radio hole hacked I need a repair piece for that too?
Old 12-22-2015, 08:03 PM   #43
chad64chevy
chad64chevy's Avatar
here is a better picture! I just measured from the top bolt hole for the rear view mirror 9" each side! I need the lip the windshield an everything inside the blue tape, thanks!!
chad64chevy is offline   Reply With Quote
Old 12-22-2015, 09:18 PM   #44
rickoner
I'm looking for this piece. Roughly 24" wide and up to atleast the dome light. If your's is available and solid, what would you want for it shipped to 15126?
Thanks.
rickoner is offline   Reply With Quote
Old 12-22-2015, 11:02 PM   #45
DPowers
DPowers's Avatar
Radio is hacked if I remember right.
How about $10.00 plus whatever shipping would be for the rocker piece?
Old 12-22-2015, 11:03 PM   #46
DPowers
DPowers's Avatar
Thanks.
I will have to remove the rear window to get that piece. How about $15.00 plus whatever shipping would be?
Old 12-22-2015, 11:04 PM   #47
DPowers
DPowers's Avatar
Will have to remove windshield to get that piece. $20.00 plus shipping work?
Old 12-22-2015, 11:40 PM   #48
chad64chevy
that will work, can you get pics of the back side after cutting it out, please
Old 12-23-2015, 03:06 AM   #49
aotte1
"Like this whole section?"
That will work, needs to be a few inches out on the flat face of firewall. or you could do two small pieces. what ever is easy for you. I will install it by replacing two smaller pieces.
Old 12-23-2015, 09:52 AM   #50
DPowers
DPowers's Avatar
Alright will see what I can do $20.00 plus shipping? I have a son that lives in Louisville and if he comes down for Christmas and I can get it cut out in time, I can see if can send it back with him, but will keep you posted.
