#26 |
Re: Gertie, the 72 c10 Highlander
Some pics of the rear...
#27 |
Moderator
![]() Join Date: Jul 2006
Looks great, this is going to be a fun truck I bet!
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#28 |
sorry my after pics of the rear are a little lackluster!
#29 |
#30 |
So here she is lowered! I am really happy with the way it turned out!
#31 |
This pic is on pretty level ground. The others make the back end look higher than it really is.
#32 |
A before and after...
#33 |
![]() Join Date: Oct 2012
Oh wow, that's great!
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554 2008 GMC Sierra Denali - 6.2L AWD - my daily 2011 Ford Flex Limited - Ecoboost AWD - wife's daily 1987 Buick Regal Turbo T - 63K miles - Strip/Street car 1965 Ford Mustang Coupe - 289, c4, 53K miles |
#34 |
#35 |
Well how about some updated… I now see how easy it is to let months pass without posting anything! Not a lot has happened in the past several months. A few minor items have been addressed, but mainly I have been parts gathering, planning, and fantasizing about everything I could do if I had deeper pockets!!!
So first up, I had my bedsides shortened and installed those. Funny how life works, I tried three times to make it down to my dad’s (where my bedsides where located); first time I just couldn’t make the three-hour drive in 20-degree weather with no heat. ![]() |
#36 |
some more pics of the new fan clutch, and removing the bedsides...
#37 |
while we had the bed off I decided to make some temporary modification to my exhaust. After lowering it, the pan-hard bar was rubbing against the exhaust making for a noisy ride down the road. So we cut it off right in front of the rear end and dumped it to the ground using an already bent section of what we cut off. Fixed my initial problem, but sure made it a lot louder in the cab...
#38 |
more pics with everything put back together.... now for some touch up paint and to reinstall all the trim.
#39 |
more pics....
#40 |
![]() Join Date: Jul 2001
Your truck is really looking good. If it was me I would play around with some paint and see if you could possibly blend the bedsides a little. I think it would come out well. Nice progress and nice truck.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
#41 |
Thanks, Ray! Yeah I agree... I bought some touch up paint from Paint Scratch so I'm hoping it matches well.
#42 |
I had been having problems with my truck stumbling and idling rough at stop lights. Also some hesitation on initial acceleration. I read several post on Edelbrock’s sensitivity to fuel pressure so I decided to check mine. I was getting between 8 and 9 psi, so I decided to install a fuel pressure regulator. (my mounting location is temporary since I will be installing vintage air in the very near future.) I set it to 5.5 and so far it has pretty much fixed my issues. I still have some hot start problems but it has helped. I decided to go the cheaper route instead of spending the $100+ on the fuel pump. Now, I’m sure that will bite me in the butt down the road but I am really thinking about a new Fitech EFI system so I am saving my pennies for now.
#43 |
Picked up some 15x8 rallys from a friend of my dads. A little elbow grease and paint... came out nice. I plan to run Cooper Cobra 255 60s.
#44 |
some more pics...
#45 |
My dad had these buckets that he wasn't currently using so I decided to use them for now. I'd like to eventually redo the bench seat but figured these would be pretty killer looking and a lot more comfortable...
I believe these came out of a 73+ blazer, so the brackets were not quite right. I decided to use ECE's passenger side brackets for both seats. This gave me the right clearance between the seat and the steering wheel without having to spend the money on an original set of 72 bucket brackets. |
#46 |
Also speaking of my dad, here is his new project. 71 CST.
#47 |
So I finally ordered my Vintage Air and it showed up the other day!
#48 |
I started prepping for my VA install... First things first, out with the old...
#49 |
Got all the interior components removed and went ahead and got my old carpet ripped out. I've noticed that a lot of projects are like the children's book, if you give a mouse a cookie, you know.. if you give a mouse a cookie its probably going to want a glass of milk... well same applies to our trucks. If you put in a new ac-heater you're probably going to want to put in new carpet and if you put in new carpet you're probably going to want to install fatmat rattle trap (and so on and so forth).... I think you get my point!
#50 |
Look'n Good in the neighborhood!!!
