#26 |
![]() Join Date: Sep 2008
Re: Porterbuilt 8 Lugger
yes absolutely keep the steelies. I vote for a set of 16.5x9.75 or widen a set of 16x7 accurides. I cant wait to lower my c20 but I want to keep it leaf in the rear.
#27 |
I'm in..I like to see this build
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#28 |
any updates? would love to see some outside full view pics!
#29 |
Got the front bags in and newer style steering gear. I might just rebuild the drums for now and focus on the air management. I have this in the side of the garage thats only 14' wide so I cant get any good side pics of it.
#30 |
Cool Truck
Very nice
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
#31 |
love that front stance! Thank you
#32 |
Super Clean Truck! I almost did this same thing on my C20, but then I saw the 22" Transport wheels. I got them super cheap, so I decided to convert to 6-lug. I now have a complete 3/5 drop kit for a C-20 I need to sell...Lol.
#33 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Drop spindles (and disc brakes) is a easy 2.5" additional drop. You won't regret it. Look at www.performanceonline.com for C20 drop spindles. Drop spindles help MORE with keeping your ride height low when you have the correct air pressure in the bags.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-31-2015 at 11:01 AM. |
#34 |
Oh, and I have the drop spindles and stock 8-lug rotors too...
#35 | |
#36 |
Any more pictures?
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank. 70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank Dads: 67 c10 step side(project) 72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter) Ours: 67 c30 tow truck 70 c10 long bed 383stroker w/digital gauges(work truck) |
#37 |
#38 |
sweet looking truck!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#39 |
Still stuffed in the narrow side of the garage so I cant get a good side shot but got the wheels and tires on.
#40 |
Looks awesome
#41 | |
#42 | |
#43 |
That looks nice. Where in Mn are you? We may have to meet for a beer, and/or pop and burger! Keep the 8 lugs going!!! 😃
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!) |
#44 |
What is the measurement from the ground to the wheel arch front n back? And what are the rim specs offset backspace n width? Tire size? I have done a rear c notch with a axle flip n kept it leaf mines 26 1/2 in the rear to the arch n front I did a drop spindle but need springs. Its at 30 1/2 now trying to decide on what spring and probably dropping the lower control arm pocket. Then very similar spoke design but all black wheels.
#45 |
#46 | |
Front is 27 3/4" stock spindles Rear is 26 3/4" with a 1.5" bumpstop Wheels are 20" x 9" +18 offset or 5.71" Tire size 245 50 20 |
#47 |
Thanks, what do you think cruising heights will be? Also what is the steering box u upgraded too? Quicker ratio? Or power?
Yr truck looks killer to me! |
#48 |
Thanks, the steering I put in a newer quicker ratio power box. I going to shoot for about 2-3" higher for a drive height. I put alot of thought and measuring into this for the backspacing and tire size. The 9" wide rim with the 50 series tire the bulge over the rim is very little. I think I can almost turn them lock to lock aired out without rubbing. I'll find out in the next few days when i get the carb done and start it up.
#49 |
Started it up today and was happy to see no rubbing at all lock to lock with it aired out.
#50 |
hmmmmm
I'm on the fence about the new rims. They look ok but the old ones have grown on me and fit the "idea" of the 8 lug stocker ![]()
'68 C10 SWB '85 K30 Blazer |
