Old 12-22-2015, 06:38 PM   #26
homemade87
Re: Gotta love the LS power
I have the ls bug and never going back . I sold ever piece of first gen stuff I had . There is no comparison in my opinion . I started with a stock 5.3 in my 82 and loved it . Now I have a ls2 ( 381rwhp ) with cam , intake , exhaust . Apparently that was not enough . I have a set of gm 243 heads cnc port from total engine air flow and new cam from Brian Tooley . Goal is 450rwhp . I think when I get to that point i will be done . Yeah right .
It amazing the power you can get from these engines .
I also have a carbed stock bottom ls2/ls3 top end ( ported ) at about 600fwhp . Talk about fun to drive .
Leestruk , I know where you are coming from . I think I have gone a little farther though and having a blast doing it .
homemade87 is offline   Reply With Quote
Old 01-03-2016, 03:21 AM   #27
BigRed76
BigRed76's Avatar
Originally Posted by slotard View Post
The 5.3 is pretty much the replacement for the 305 so it isn't a big surprise that it's sluggish with 2.73 gearing.
You must have never owned a 305. Stock vs. stock, the 4.8 is like the replacement for a 350.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-03-2016, 01:32 PM   #28
slotard
My impression is that 305 and 5.3 are the most common engines - certainly the most common V8s - in vehicles that offered them. Yes, the 5.3 makes a lot more power, but there were reasonable 305s as well.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-03-2016, 04:20 PM   #29
Daaaanz67
DO NOT I REPEAT DO NOT UNDER ESTIMATE THE 4.8, mine runs like a beast in stock form.
Daaaanz67 is offline   Reply With Quote
Old 01-03-2016, 10:46 PM   #30
MalibuSSwagon
Honesty however, after towing a couple times more, it is a marked improvment over the 305. However with the 2.73's and the SM465, it's like driving a Semi loaded, gotta use all the gears.
MalibuSSwagon is offline   Reply With Quote
Old 01-03-2016, 11:18 PM   #31
aknovaman
Yeh, 4.8L never put out much power and are not worth messing with.
http://youtu.be/MwJYPsJfDvE
Not bad for a 4800 pound truck.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 01-04-2016, 12:38 AM   #32
72MARIO
72MARIO's Avatar
Glad I found this post. I was worried about the truck i just bought as a doner for my 1968 Suburban. Its a 2003 with a 4.8 240000km got the complete truck for $500 delivered to my shop. Really wanted a 5.3 but the price was right and the truck has no noise starting from cold at -8. I should be able to sell $500 worth of parts off it
We do use the suburban to tow with. I figured that i will try it out and with a proper tune it should be better than the stock 327 thats in it currently.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-04-2016, 10:17 AM   #33
MalibuSSwagon
That's about the amount of mileage my 5.3L has on it. Tows great as you can see, and thats on the stock tune. You should have no issue selling off $500 worth of parts. Don't forget cores! Cat converters, brake calipers, master and booster, wiper motor, all worth money at a recycler. I made $200 back on just the cats alone!
Old 01-04-2016, 11:46 AM   #34
slotard
About the only thing I'd be worried about is the transmission. The 4L60E isn't known for it's longevity.
1973 C20, 350/350
Old 01-04-2016, 12:06 PM   #35
Heavymetl
Here's a great example of just how badly the "old-school" engines are starved for air.
Everyone knows Hot Rod does all their dyno testing at Westech, and they've recently done a couple of totally non-related articles/shows that are fairly eye popping.
Example one:
383 Chevy, Vortec Heads, 230/236 hydraulic roller, dual plane intake, carb.
440.1HP@5600 / 464.9TQ@4200
https://www.youtube.com/watch?v=L-uV61qilqU
Not a bad combo, and obviously due to the cubes excellent torque numbers.
Example Two:
Junkyard LM7 5.3. Stock dished pistons, stock 862 heads (small valve, known for being "junk" in the LS world), tiny 224/232 cam.
442HP@6200 / 412TQ@5000
http://www.hotrod.com/how-to/engine/...st-comparison/
Same dyno, incredible results. The 383 certainly made more torque, and would undoubtedly be faster in a vehicle going down the track. But for a run-of-the-mill, garden variety LM7 5.3 (I bought for for $550) with a cam change it is impressive and really illustrates how much potential lies in even the small cube LS engines.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 01-04-2016, 12:16 PM   #36
homemade87
The 4l60e does pretty good if you take care of it . Most high performance mods does beat on them pretty good . Heat is the biggest killer .
Get the biggest trans cooler you can fit in there and run it thru the radiator as well as the cooler . Don't skimp on the cooler . Also if you are getting a tune get the torque management turned off or reduced . It will keep the clutches from slipping as much when towing during shifts .
