Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 12-24-2015, 12:36 AM   #26
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: Diesel C60?
Here is a quick example of a 3-53:
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 12-24-2015, 12:40 AM   #27
jaybatta
jaybatta's Avatar
Re: Diesel C60?
Originally Posted by Jim Timber View Post
Radiator hoses, various accessory brackets for the engine, etc. The engines themselves are pretty universal, but water pumps can vary a lot in how they route the heater hoses and the radiator hoses. Then you have things like alternator mounts for odd positions because of the air pump, etc.
I'm curious what all is universal to a big/small block or what's specific to the medium duty chassis. The radiator's look much bigger than any light truck I've seen. Higher cooling capacity isn't a surprise at all, but that also means the water pump might flow at a different rate too.
The water pump in the 60 visually looked a lot different. However, the radiator I was expecting to be a 4 core. It did not appear to be. Looked like a 3 core at best. It very well could have been born with a 4 core and replaced with whatever was available. It doesn't get incredibly hot for long periods of time in Montana.
Joe
1968 K20
1970 K20
Semper Fi
jaybatta is offline   Reply With Quote
Old 12-24-2015, 12:41 AM   #28
jaybatta
jaybatta's Avatar
Re: Diesel C60?
500# sounds like a lot, but stiffer springs and more ply tires make it work out in the end. For a vehicle that can handle an extra two tons out back, another 500 up front isn't a deal breaker.
You will notice it though. Diesels are heavy!
If you stick to a truck engine, the rotational direction will be standard. The problem mentioned comes into play when you start looking at marine application engines and generators - both of which can have the crank on the wrong end of the block depending on who bought the engine for what application.
Ahhhh I understand now
Joe
1968 K20
1970 K20
Semper Fi
Old 12-24-2015, 12:42 AM   #29
jaybatta
jaybatta's Avatar
Re: Diesel C60?
Mr.Bill, could you share that link? For some reason I'm not able to play that YouTube video on this device
Joe
1968 K20
1970 K20
Semper Fi
Old 12-24-2015, 12:49 AM   #30
Jim Timber
Re: Diesel C60?
www.youtube.com/watch?v=1fS43WnFGWs
I've never seen a jake on a little truck with a DD. That's awesome!
Jim Timber is offline   Reply With Quote
Old 12-24-2015, 12:53 AM   #31
C10 - C90 Bill
Re: Diesel C60?
Here is a 4-53T with a 10-Speed Road Ranger:
We could do without the talking in the video, but it's the only one I could find of it.
GMC 9500 Fan
Detroit Diesel Fan
Old 12-24-2015, 12:57 AM   #32
C10 - C90 Bill
Re: Diesel C60?
Link:
https://www.youtube.com/watch?v=AnhHA_B3uvM
GMC 9500 Fan
Detroit Diesel Fan
Old 12-24-2015, 07:23 AM   #33
84rzv500r
Re: Diesel C60?
http://67-72chevytrucks.com/vboard/s...d.php?t=599758
this is why they didnt use 8V-71 from the factory
72 GMC K5500 Napco 4x4 8V71/RTO-9513/T-1138
71 Corvette Wide Body 502 Ramjet
83 HD XR1000, 99 HD XL1200S, 84 YAM RZV500R
05 MB E55 AMG, 12 45th Camaro SS stick vert
84rzv500r is offline   Reply With Quote
Old 12-24-2015, 09:24 AM   #34
Re: Diesel C60?
500# is nothing to a light truck. Just bump the springs. 1t should handle it fine.
Old 12-26-2015, 09:12 PM   #35
C10 - C90 Bill
Re: Diesel C60?
Here is what a 4-53 looks (and sounds) like. This is a 4-53T. Looks like he has plans to drop it into a '72 GMC 1-Ton:
GMC 9500 Fan
Detroit Diesel Fan
Old 12-26-2015, 10:48 PM   #36
68 CRACKERBOX
68 CRACKERBOX's Avatar
Re: Diesel C60?
here is the one in wis. Jim Timber told us about. 81 c-70 453t. I think Monday I'm going to buy it.
short bed are just cars without trunk lids
trucks have long beds
real trucks are longhorn
72 gmc 2500 longhorn
68 chevy c-30 50th anniv. 9ft step side
68 gmc crackerbox 8v71 detroit
72 gmc astro95 8v71 detroit
68 CRACKERBOX is offline   Reply With Quote
Old 12-26-2015, 10:59 PM   #37
jaybatta
jaybatta's Avatar
Re: Diesel C60?
If you get it, keep me (us) posted on how it turns out. I'm excited to see it run
Joe
1968 K20
1970 K20
Semper Fi
Old 12-27-2015, 05:16 AM   #38
Jim Timber
Re: Diesel C60?
It runs and drives - so they say.
Did they let you have it for a K?
Old 12-27-2015, 11:44 AM   #39
68 CRACKERBOX
Re: Diesel C60?
2k
Old 07-05-2024, 10:15 PM   #40
ClassicTVMan1981X
Re: Diesel C60?
While I know about the use of the 4-53 Detroit Diesel two-cycle engine as well as the Toro-Flow D-478 V-6 in these, I wonder if any of the '67 to '72s were changed to the "Fuel Pincher" 8.2L diesel V-8 (available naturally aspirated up to 165 hp, or turbocharged with 205 or 230 hp) during the 1980s?
In theory, because the 1980-84 Chevy and GMC B6P school bus chassis did use the 8.2L, I believe these '67 to '72s could have had the 8.2L as a replacement engine for some customers. If any of you happen to have a '67 to '72 C50, C60 or M60 with the 8.2L, please let me know. Some of the '78-'80 C50s, C60s, M60s, C70s and M70s could be had with the 4-53T two-cycle diesel.
For all you D-478 fans, this is what that engine sounds like (in this 1971 GMC TDH-3301 bus):
https://www.youtube.com/watch?v=azZHQa9dgmU
~Ben
ClassicTVMan1981X is offline   Reply With Quote
Old 07-06-2024, 09:15 AM   #41
C10 - C90 Bill
Re: Diesel C60?
Here is another D-478 video I found online:
GMC 9500 Fan
Detroit Diesel Fan
Old 07-06-2024, 02:19 PM   #42
CarolinaHD
Moderator
CarolinaHD's Avatar
Re: Diesel C60?
Diesel options from my 1967 40, 50, 60 series catalog
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 07-09-2024, 07:18 PM   #43
Bob B.
Re: Diesel C60?
~Ben
I don't recall ever seeing any '67-'72 medium duty trucks with 8.2's, but I know that a few GM TDH-3501 transit buses had their D478's replaced with 8.2L's.
The 4-53 was replaced in the C-60's by the 8.2L in mid-'80.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 07-10-2024, 06:55 PM   #44
C10 - C90 Bill
Re: Diesel C60?
Bob,
Still never checked my books, lol, but I was surprised to see a 4-53 listed for a '67 C-50 and 60 in the spec sheet above. Did it actually make it to production? And if it was, was this the last year for it? It wasn't that long ago that we were talking about the 4-53's not available in these mediums.
GMC 9500 Fan
Detroit Diesel Fan
Old 07-11-2024, 12:30 PM   #45
Bob B.
Re: Diesel C60?
Bob,
Looks like 1969 was the last year for the 4-53 powered Chevy CD50 and CD60. Rare but they did build a few. The 4-53 came back as an option in the C series in 1978.
Old 07-11-2024, 12:42 PM   #46
C10 - C90 Bill
Re: Diesel C60?
Interesting. I clearly remember the '65 having a 4-53 as well as quite a few newer models as mentioned, but never saw or even heard of one in a '67-'69 Medium. I wonder what the reason was other than customer preference? Strange there weren't a lot more.
GMC 9500 Fan
Detroit Diesel Fan
Old 07-11-2024, 03:59 PM   #47
Bob B.
Re: Diesel C60?
Being noisy, slow, and somewhat expensive didn't help! Most of the 1978 and newer ones had 4-53T's in them. A little better.
Old 07-12-2024, 06:58 PM   #48
C10 - C90 Bill
Re: Diesel C60?
Bob,
What was the first year for the "T" ?
GMC 9500 Fan
Detroit Diesel Fan
Old 07-22-2024, 12:53 AM   #49
Bob B.
Re: Diesel C60?
Bob,
Sorry, couldn't find anything definitive. I think it was 1978.
Old 07-22-2024, 08:45 AM   #50
C10 - C90 Bill
Re: Diesel C60?
Sounds about right to me.
Sure would had been nice if it were 15 or 20 years earlier.
GMC 9500 Fan
Detroit Diesel Fan
