Old 03-15-2016, 12:36 AM   #26
picklito
Re: 67 GMC Quick Build
Inspiring! You do make it look easy. Super clean work.
picklito is offline   Reply With Quote
Old 03-15-2016, 04:44 PM   #27
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
Thanks!
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 03-15-2016, 05:51 PM   #28
Rod Run
Rod Run's Avatar
clean looking build
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 03-22-2016, 10:06 PM   #29
Bagd72Chevy
C10 Collector
Been working on the harness. Got the firewall plug installed and harness on the motor. Got to do the firewall to pcm wiring now. The pcm and fuse panel will be under the seat.
///Ryan
1971 Blazer - Rusty
Old 03-22-2016, 10:27 PM   #30
picklito
Enjoying your build and I'm learning a lot! Have to say, getting the wiring sorted out on mine transformed the truck.
Old 03-23-2016, 04:02 PM   #31
Bagd72Chevy
C10 Collector
I just realised I never put any pictures of the engine.
Painted int he proper color first.
Bought a Cam
Swapped the Cam
Made a valve spring tool
Changed the valve springs
And that is the motor that will be running in the truck for stage 1.
Stage 2: CNC port adapters for LSA blower and LSA blower.
///Ryan
1971 Blazer - Rusty
Old 03-23-2016, 04:04 PM   #32
Bagd72Chevy
C10 Collector
I also made up some coil brackets to mount some GMC valve covers as coil covers but they are too tall and hit my booster on drivers side and firewall on passenger. Maybe I can clearance them, not sure.
///Ryan
1971 Blazer - Rusty
Old 03-24-2016, 12:18 AM   #33
tinydb84
tinydb84's Avatar
Looks great! One question: Why did you raise the upper control arms?
David
Instagram: myfabguy
Old 03-24-2016, 12:57 AM   #34
Bagd72Chevy
C10 Collector
Im running 2007 Silverado front spindle assemblies. I flipped the lower ball joint which equates to ~3.5" drop spindle. C10 ball joints point up and late model gm ball joints point down. So I reamed the spindle from the bottom to put on the C10. The later model spindle is much taller, has disc brakes, and is 6 lug. To get the front geometry correct the upper control arm had to be moved around. Caster/Camber/Toe is all static and done with an alignment but the caster gain, camber change, and toe change are all dynamic and are designed into the geometry. I used LOTUS suspension analysis software to optimize my geometry for what I believe I want. Once I drive it I'll report back on how I did, LOL.
///Ryan
1971 Blazer - Rusty
Old 03-24-2016, 01:01 AM   #35
Bagd72Chevy
C10 Collector
So now the truck has 2007 spindles, brakes, wheel bearings, calipers on the front.
2007 calipers, rotors, and parking brake out back. 2007 engine.....my take on a daily driver C15.
Also now the front wheels have speed sensors which I will use towards my traction control someday. Hopefully it'll do decently well at good-guys auto-x, and more importantly Power Tour.
///Ryan
1971 Blazer - Rusty
Old 03-24-2016, 01:52 AM   #36
Sac
Cool build. I'm right down the road from you.
Green Survivor Father/Son Truck
<SeveredTies>
Sac is offline   Reply With Quote
Old 03-24-2016, 01:54 AM   #37
tinydb84
tinydb84's Avatar
Ah makes sense! I missed the caliper swap. Very cool!
David
Instagram: myfabguy
Old 04-05-2016, 01:01 PM   #38
Bagd72Chevy
C10 Collector
Raised the factory inners and threw some paint on the fenders. The doors came out crappy so I reworked them while I was at it. Still need to align the fenders, just threw them on for the trip home.
My famous glass friend threw my windshield in
///Ryan
1971 Blazer - Rusty
Old 04-13-2016, 01:16 PM   #39
sdwolff98
Turning Wrenches Daily
Bagd,
What did you do for ball joints on the front arms? I am curious I am pursuing something similar on my 64 3/4 ton truck?
thanks
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 04-13-2016, 01:52 PM   #40
Bagd72Chevy
C10 Collector
Originally Posted by sdwolff98 View Post
Bagd,
thanks
Sean
I put in later model ball joints. Like 85ish. Same thing on inner tie-rods. I reamed out the centerlink for the larger tie rods.
///Ryan
1971 Blazer - Rusty
Old 04-13-2016, 02:18 PM   #41
sdwolff98
Ryan,
did you have to ream the spindle as well? I currently have 79 disc front brakes on my 64 gmc with the later ball joints. Interesting I did not have to ream my center link for the newer tie rods interesting??
Sean
Old 04-13-2016, 02:43 PM   #42
Bagd72Chevy
C10 Collector
Yes my spindles are off of a 2007 Silverado. I completely redid the front suspension geometry.
///Ryan
1971 Blazer - Rusty
Old 04-13-2016, 03:23 PM   #43
sdwolff98
Thats awesome how much further in did you have to bring the upper arms to get everything lined up?
Sean
Old 04-27-2016, 09:11 AM   #44
Bagd72Chevy
C10 Collector
First Start Video
///Ryan
1971 Blazer - Rusty
Old 04-27-2016, 09:25 AM   #45
projectking
projectking's Avatar
Great work, truck looks sweet!
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 06-20-2016, 09:53 AM   #46
Bagd72Chevy
C10 Collector
Well, havent been working on the truck too much. Bought a new house with no garage so I've been organizing and trying to store all my spare parts/tools. Good news is after my old house sells I'll be breaking ground on a new garage. But here's a pic of the truck now. Need to raise the front an inch or 2.
///Ryan
1971 Blazer - Rusty
Old 10-25-2016, 05:04 PM   #47
Bagd72Chevy
C10 Collector
Been awhile since I posted. Wife and I flooded back in August and everything has been crazy since. The 67 was at my dads shop getting ac charged luckily so it was spared. The bed was off and flooded. And my 67 Chevy flooded. At its crest the water was just above the bottom of the door of the truck. Water stayed in the house for over 6 days. But we are rebuilding. I sandblasted the bed and got it in Epoxy to get it back on track. The shipping container was filled to the top with C10 parts and all my tools. It had about 8" of water in it and then baked like a Sauna. Lost alot of parts. Axles, gears, posi's, transmissions, engines.
///Ryan
1971 Blazer - Rusty
Old 10-25-2016, 05:17 PM   #48
MMcMasters
MMcMasters's Avatar
Man, that is horrible. I hope your insurance made you whole again.
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 10-25-2016, 05:23 PM   #49
Bagd72Chevy
C10 Collector
We are still fighting the insurance battle, but at least we have that. Many people who flooded this time did not have insurance, were not in flood plains, etc. Its crazy where the water went and the damage it did. My wife and I have a Fema trailer to stay in now so at least we are kind of home. Just working on the cleanup. House is completely gutted now. Once insurance settles we will start the rebuild.
///Ryan
1971 Blazer - Rusty
Old 10-31-2016, 12:16 AM   #50
swamp rat
swamp rat's Avatar
Man that's gotta suck after just buying the place, may the new garage be a second story!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
