#26 |
I'm just glad to be here!
Re: 12 Bolt Drum Brake Upgrade
Yes. Does not change the overall width of the axle.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#27 |
![]() Join Date: Oct 2013
Karl,
Finally got the side by side photos, took me forever to get the work bench cleaned off!!! Let me know if more photos will help. The '79 brake shoes are on the left and the '77 brake shoes are on the right. The lining material area is the same on both. The size specification are the same for both. They do have different part numbers. The brake shoe frames are made a little different, however, both sets of shoes, mounting hardware and emergency brake fit the '77 backing plate. The '79 brake shoe frame is a little thicker then the '77. The '77 frame has double material at the top, which you can see in later photos. The holes in the frames are also a little different, however, those used for this application are the same - so no matter. Also, more information is provided in above posts. Les Last edited by aotte1; 01-24-2016 at 08:30 PM. |
#28 |
A few more photos. In the second photo you can see additional material added at the top of the '77 brake shoes. Photo three shoes the '79 without this additional layer, however, the frame material is thicker then the '77.
Les |
#29 |
That's what I thought was the difference between the years. So, the later model shoes will work and fit in place of the 76-77 shoes with no issues. It appeared to be a manufacturing/engineering change to the frame and not to the actual lining. The frame change on the shoe would have made them quicker and less expensive to produce those parts.
#30 | |
O
Note: The brake drums for this application are a LOT bigger, then the smaller two inch ones that came on the '65 12 bolt. Les |
#31 |
Going to dredge up an older thread here, but I was wondering where someone could buy the backing plates? I can get every part from the auto store, except the backing plates. Any info is appreciated.
#32 |
Not sure if new ones are available? Lots of them should be available on trucks, subs and blazers being parted out with 12 bolt rears. Also, could post a WTB request in the parts section. Not sure when first used, '77 to '87 trucks and '91 subs/ blazer could have them. A key way to identify vehicles, that have these backing plates is to look for 1 1/4 inch wide front rotors, they are the JB5 brake package.
Hope this helps, Les |
#33 | |
#34 | |
#35 |
So just to confirm that these will work on pre-70.5 (narrow axle) trucks as well? I have searched and googled and know they WILL work with anything 70.5-87 (wide axle). Can't find anything confirming fitment on narrow axles.
I have an 87 Blazer setup I'd like to install on my 69. Thanks in advance. |
#36 | |
#37 |
" Correct. It will be a bolt-on upgrade for your '69. "
Sweet. Thanks racecougar! |
#38 |
![]() Join Date: May 2009
Hope to find a set up in the bone yard
#39 |
Correct.
#40 |
I know this is an old thread but i need help I NEED a set of backing plates for my 12 bolt with the 2.75 inch wide shoes. Where can i buy these backing plates. I had a guy send me a set off of these off of this site and i JUST found out they are for the 2 inch wide shoes. nothing will line up. I'm in desperate need of these backing plates. Help me find a set
#41 |
AFAIK, the only way to get a set is off a later 12-bolt. I haven't seen them reproduced.
#42 |
#43 |
Yes, but look at the 1/2 ton vans of the same era, they should have the same rear axle and could possibly have the correct backing plates too.
